Old 06-15-2014, 05:31 AM   #1
paulca
Drives: Toyota GT86 Coupe Red (UK)
Gas/Petrol Octane
Just an observation, but looking through posts on here it looks like a lot of you US guys are stuck with 91 and 93 RON unleaded.
Totally bizarre. Over here in the UK basic bargain supermarket petrol from the likes of Tesco's or Asda(Walmart) is 95 RON.
BP Ultimate 97 is what I've settled on as it's easily available locally.
Tesco's do "Tesco 99" and Shell do V-Power Nitro 99. I'm not sure I would trust Tesco 99 and there are no shell stations in my area.
BP also do Ultimate 102, but I haven't seen it yet.
The petrol filler has a sticker on it in the UK says something like "98 RON Unleaded only!"
I understand the engine will adjust the timing of course, but with higher octane fuel you apparently get more ignition advance and slightly more power and/or better economy.
Downside, of course, is over here BP Ultimate 97 costs $2.34 a litre, crica $8.86 a US gallon. An average fill up costs me about $90-100.
paulca is offline   Reply With Quote
Old 06-15-2014, 05:42 AM   #2
Fortis
Fortis's Avatar
Drives: 2014 FR-S AT Asphalt
I hear 93 octane is readily available in the eastern parts of the US but out here in California I never see anything higher than 91
Fortis is offline   Reply With Quote
Old 06-15-2014, 06:01 AM   #3
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
All true. 91 octane is the highest around here, and according to pure-gas.org there are 14 ethanol-free stations in the entire state (38 million people)
I fixed that problem by running E85. Now my bone-stock twin feels like it has S2000-levels or pull towards redline, except with a less peaky powerband.
unsurety is offline   Reply With Quote
Old 06-15-2014, 07:05 AM   #4
PatSciFRS
Drives: Scion FRS 10 Series
US Octane is in AKI units
In the US, the octane rating is listed in AKI units whereas in the UK it in in RON units. They differ by about 4 to 5 points according to Wikipedia. So an octane of 93 in the US is basically 97-98 RON.
PatSciFRS is offline   Reply With Quote
Old 06-15-2014, 07:59 AM   #5
AJPG
Drives: 22RE, FA20, 4G63
In my area you could get 93octane for $4 us gal, there isn't E85 at least that I know, but I found in the commute to work Sunoco 100 at the pump and yes sir! The car will run better, don't know if could track down the s2000 with the gas only, but if you have mods (FI) and retune expect from 30 to 50 whp more that whatever was the base.
Ej. SC kit could get you to 250 whp, with the gas and tune maybe you could hit the 300 whp. At $10.50 us gal
AJPG is offline   Reply With Quote
Old 06-15-2014, 11:25 AM   #6
Frstorm
Drives: 2013 Firestorm
I an 93 nonethanol until I moved now I run 92 nonethanol
Frstorm is offline   Reply With Quote
Old 06-15-2014, 01:24 PM   #7
strat61caster
strat61caster's Avatar
No, our gas is rated in AKI.
http://en.wikipedia.org/wiki/Octane_...ndex_.28AKI.29
ineedyourdiddly
Old 06-15-2014, 05:34 PM   #8
paulca
Ah, that makes more sense.
Old 06-15-2014, 05:36 PM   #9
jainish007
Drives: 2014 Monogram Scion FRS Whiteout
just a random thought, Does weather affect the fuel. I mean in US mostly California, we have warm weather through out the year. I think that might help fuel to ignite or evaporate better than in cold weather!
jainish007 is offline   Reply With Quote
Old 06-16-2014, 03:15 AM   #10
paulca
Cold air is more dense and contains more O2. (think intercooler) I think slightly damp air is even better.
In Ireland I swear you notice it on cold mornings.
Warm climates may encourage evaporation of the more volatile compounds, but surely for hot countries they have additives for that or fuel would have a much shorter shelf life or need to be stored in unvented tanks.
Old 06-16-2014, 05:34 AM   #11
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Here in France we get either 98 RON, 95 RON or 95E10 RON 10% Ethanol.
I've tested 95E10 and 98 and both seem to work the same....
Harvey is offline   Reply With Quote
Old 06-16-2014, 10:12 AM   #12
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Correct!
billwot is offline   Reply With Quote
Old 06-16-2014, 10:45 AM   #13
billwot
Actually, cold temps increase performance, but warm weather increases MPG.
Weather doesn't really effect "fuel", but it does effect the density of the A/F charge. Cold air is more dense, so lower ambient temps actually increases the amount of A/F into the engine. And you not only get a bigger A/F charge, yoou get an increase in the effective CR...its like free FI.
Old 06-16-2014, 11:14 AM   #14
paulca
You get more fuel if you fill on a cold day.
100 Octane? hellyvin Northern California 23 07-24-2017 08:01 PM
93 Octane vs 91 Octane keithgold Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 01-16-2014 10:16 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
110 octane EZWood Engine, Exhaust, Transmission 19 06-29-2012 08:12 PM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 12:22 PM
