Old 06-02-2014, 02:04 AM   #15
86Kenshin
86Kenshin's Avatar
Drives: Toyota 86 A/T
Problem solved ! The flashing CEL is now gone, here is what I found:
The DCC fuse (30A) was never removed from the "delivery" position during PDI into its original location, instead, there was a (15A) fuse installed, here is the pic:
It should be like this (pic form internet):
fuse box cover picture to confirm:
Name:  fuse box cover.jpg
86Kenshin is offline   Reply With Quote
The Following User Says Thank You to 86Kenshin For This Useful Post:
Sportsguy83 (06-02-2014)
Old 06-02-2014, 08:52 AM   #16
andrew20195
Drives: 2013 Subaru BRZ
Originally Posted by pche View Post
Btw, I've PDI quite a few BRZs, never had I disconnect the D-check connector. It's not under the kick panel like the PDI sheet suggest. I don't think it has one, at least the BRZs don't.
Only the 2013 premium (normal ignition key) 6AT cars have that connector. I was confused myself when I started doing the PDIs on them. For 2014 the 6AT is only available in Limited, so none of them have that connector anymore.
andrew20195 is offline   Reply With Quote
The Following User Says Thank You to andrew20195 For This Useful Post:
pche (06-02-2014)
Old 06-02-2014, 10:36 AM   #17
pche
Guy on internet
Drives: Slowly
Attachment 80538
Attachment 80539
Attachment 80540
Good, that'll be 89.95 for the hour diag, I take PayPal. Thank you come again.
pche is offline   Reply With Quote
BRZ jammed window issue/blinking auto light? Superhatch Issues | Warranty | Recalls / TSB 28 02-15-2015 05:45 AM
What is that blinking dash light when the car is off? JayNutter Scion FR-S / Toyota 86 GT86 General Forum 7 02-03-2014 10:59 AM
Question on fog/3rd brake light blinking fx35s Cosmetic Modification (Interior/Exterior/Lighting) 14 01-26-2014 01:32 PM
OEM JDM Tail light Blinking Fast ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 06-13-2013 12:32 AM
CEL Blinking/Hard Shaking. _F-R-S_ Issues | Warranty | Recalls / TSB 4 09-16-2012 07:43 PM
