Old 05-05-2014, 10:39 AM   #15
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
This thread is turning out to be the thread I was hoping it would be. haha.
blackfireball5 is offline   Reply With Quote
Old 05-05-2014, 12:25 PM   #16
bluesubie
Originally Posted by Gords_zenith View Post
I would hazard a guess that our cars are spec'd for a viscosity of ~7 cST @ 100C, based on the fact that the stock 0W-20 is rated for that. So in saying that, our cars run hot when being beat on, that raises the temp up to 110-120-130 degrees celsius, so from that I would conclude that the stock 0W-20 at those temps drops to a viscosity rating of ~4-5 cSt which in my mind is not good. but if ya want to keep using the OEM Mobil 0W-20, that I would think having a thermostatically controlled oil cooler would be good investment.
see my post:
http://www.ft86club.com/forums/showthread.php?t=63955
EDIT: this doesn't tell you what pressure you will get, but will give you an idea of what oil you should run based off temp to ensure oem designed oil pressure is maintained.
Looks like the viscosity@ 100C for your Subaru BRZ OEM (Idemitsu, BTW. Toyota service fill is XOM) is based a used oil analysis. You should look for a virgin oil analysis of the Subaru and Toyota oils for a slightly better comparison.
Also, HTHS viscosity affects oil pressure as well.
-Dennis
bluesubie is offline   Reply With Quote
Old 05-05-2014, 06:31 PM   #17
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
-Dennis
Ya I figured it was a bit on the low side because being used. thanks. I'll keep looking.
Gords_zenith is offline   Reply With Quote
Old 05-05-2014, 07:05 PM   #18
protpibe
protpibe's Avatar
I have an Innovate MTX and it maxes out @ 100psi on cold start. Driving around town I see around 17psi at fully warmed up at idle and 15psi if I'm really banging on it. I did 12 runs @ an AutoX practice day and as temps rose, the pressure dropped. At it's lowest, I think I saw 9-10psi @ idle, which was after 4 runs in quick sucession. I should note that the temp maxxed after 2 runs back to back and stayed there.
A good rule of thumb is about 10psi per 1000rpm, like someone else mentioned.
The Following User Says Thank You to protpibe For This Useful Post:
blackfireball5 (05-05-2014)
Old 05-20-2014, 03:48 AM   #19
fooyc
fooyc's Avatar
Drives: GT86-JDM
even I run on 5w50 the oil press is still low...
fooyc is offline   Reply With Quote
Old 05-20-2014, 01:04 PM   #20
Dezoris
Dezoris's Avatar
I should have my temporary oil pressure gauge installed this week. One thing is when you are somewhat reverse engineering data it's hard to get a baseline without others participating. I think this motor is very efficient.
I have not seen any proof so far 0w20 is bad for this car. Its obvious regardless of oil choice to have a cooler installed if you track the car. But it will be good to get some data on pressures in this thread.
Old 05-20-2014, 01:39 PM   #21
blackfireball5
I'll be installing my Gauge hopefully this week as well. Mine won't be much help determining a baseline through. I am running 5w30 with a full blown turbo kit and an oil cooler. But I'll report what i get to compare when i test it out.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 05-20-2014, 02:06 PM   #22
protpibe
protpibe's Avatar
I went to an hpde last weekend and saw pressures drop to about 45psi at 7000rpm at 250-260f after a bunch of laps. AVO turbo at 7psi with 300v 0w20
I'll be investing in an oil cooler soon. I'm thinking maybe the robispec setup or a water one
Sent from my HTC One using Tapatalk
Old 05-20-2014, 02:51 PM   #23
Dezoris
Dezoris's Avatar
I have the oil gallery plug for NBT and Prosport gauge (temp).
Been trying to figure out where I am going to wire it to and how to do the dimmer, I have never really ****ed with that stuff before. What are you plans for that?
Old 05-20-2014, 03:00 PM   #24
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The 250-260F isn't a problem for the oil but I can see being FI, the bringing the oil temps down will reduce the possibility of detonation. Definitely want to get the pressure up.
I'm not comfortable with 45psi at 7k. If you go track your car again before getting a cooler, try some 5w-40 and report back.
SCCA T4 - FRS
Old 05-20-2014, 03:16 PM   #25
blackfireball5
I have the same. A 52mm prosport gauge with the oil gallery plug. The previous owner of my vehicle installed a boost gauge near where I'm putting the oil pressure gauge so I'll most likely tap into the same lines the boost gauge uses. I'll see if i can tell what lines he used when i install mine.
Wheelwell Profile
Old 05-20-2014, 03:25 PM   #26
protpibe
protpibe's Avatar
Yeah the temp doesn't bother me as much as the pressure drop. I was thinking of trying 5w30 since I DD it significantly more than I track it.
Old 05-22-2014, 01:43 AM   #27
Dezoris
Dezoris's Avatar
Installed the gauge tonight, and noticed they sent me the wrong one of course after I completed the install. Pain in the ass.
The Following User Says Thank You to Dezoris For This Useful Post:
blackfireball5 (05-22-2014)
Old 05-23-2014, 03:51 AM   #28
Dezoris
Dezoris's Avatar
Interesting initial data collection, its clear oil temp plays a major roll in pressures.
0W20 Redline (Fresh Change)
IDLE OIL PRESSURES
175F = 19PSI
190F = 15PSI
198F = 11PSI
210F = 9PSI
The Following 5 Users Say Thank You to Dezoris For This Useful Post:
blackfireball5 (05-23-2014), Bonburner (03-30-2021), dp1 (05-23-2014), Draco_PR23 (05-24-2014), jcw99 (06-26-2016)
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
Mid range really lacking goli5oda Electronics | Audio | NAV | Infotainment 4 08-19-2013 11:27 AM
Range on a tank of Gas! crank Southern California 28 02-10-2013 05:04 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 03:31 AM
UK Price range £25-£32k!? ZeeSpeed Scion FR-S / Toyota 86 GT86 General Forum 56 11-27-2011 03:11 PM
