Old 05-16-2014, 12:02 PM   #15
weepel
Dr. Fünke, Analrapist
weepel's Avatar
Drives: 2013 BRZ Limited, 2004 WRX STI
4.4.2 Bluetooth
Just a heads up, I'm running 4.4.2 via CM11 Snapshot and no longer have the Bluetooth disconnect issues I was experiencing with a rooted stock Sense KitKat ROM:
weepel is offline   Reply With Quote
Old 05-16-2014, 12:03 PM   #16
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
I am also having this issue. The display will flash across the screen "Mobile Device has Been Disconnect," poor grammar and all. My phone still shows connected on its side. I brought it to the dealer and they have a new radio on order. This is with my Nexus 5 which I saw mentioned above.
Luckrider is offline   Reply With Quote
Old 05-16-2014, 12:04 PM   #17
Luckrider
Luckrider's Avatar
I have been thinking of switching to CM11 (because I loved CM10 on my Droid 4 so much) for other reasons, but if this works, I would be super happy.
Old 05-16-2014, 12:07 PM   #18
weepel
weepel's Avatar
You don't spreak Engrish?
Old 05-19-2014, 05:41 PM   #19
uEih
Drives: CBS Subaru BRZ Limited
Ok so my phone use to be great and worked perfectly for the first few months, no disconnect. I upgraded to kit kat and started getting some disconnect. I have a Nexus 4, I have found the solution at least to my issue and most likely others. I'm downtown a lot in my city and it gets pretty compact downtown, a lot of wifi signals so one day I kept getting disconnected from my bluetooth every few minutes and thought that was odd. Then I found it sometimes when I leave my house and start my car it'll disconnect as I' driving away. I came to the conclusion it's the wifi.
You guys can try this next time and see if it works, an annoying hassle but I do it all the time now since I rather not have the annoyance of disconnection. When you leave and get in your car, turn wifi in your phone off. I found the reason my phone/head unit disconnects is because it picks up wifi signals and tries to connect/disconnect. That's why when driving in a condensed area it picks up a lot of wifi signals so it disconnects all the time. When leaving my house it's disconnecting from the wifi as I'm driving away which leads to the bluetooth issues for some reason. This seems like an easy software fix with an update for the head unit. For some reason the wifi and bluetooth gets confused or mixed up.
After turning off wifi every time I get into my car I don't get disconnected at all. Might not be a universal fix but it is for me and I'd say most likely for a lot of people also.
uEih is offline   Reply With Quote
Old 05-22-2014, 08:31 AM   #20
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Glad I found this thread. I've been having this disconnect issue with my Nexus 5 bluetooth audio recently.
I'll try these fixes!
Old 01-26-2023, 12:00 PM   #21
rahulkapoor
Drives: bmw
There could be a few reasons why your BRZ Bluetooth phone is disconnecting. Some common causes include:
The device being too far away from the car's Bluetooth receiver
Interference from other electronic devices
A low battery on the phone or device
An outdated Bluetooth version on either the phone or the car
A problem with the car's Bluetooth system or the phone's Bluetooth settings.
You can try resolving the issue by trying the following steps:
Bring the phone closer to the car
Turn off any other electronic devices that may be causing interference
Charge the phone or device
Check for updates on both the phone and the car's Bluetooth systems
Restart the phone and the car.
If the problem persists, you may want to contact the car's manufacturer or your phone's manufacturer for further assistance visit more.
rahulkapoor is offline   Reply With Quote
Disconnecting the battery? Reflex Electronics | Audio | NAV | Infotainment 4 04-08-2014 01:55 PM
List (you contribute) Phone Bluetooth Compatibility BRZ stock headunit robot Electronics | Audio | NAV | Infotainment 15 01-09-2014 01:44 PM
Bluetooth audio from android phone cgrey Electronics | Audio | NAV | Infotainment 10 07-11-2013 07:56 AM
Stream music from smart phone to car via bluetooth itisthumper Electronics | Audio | NAV | Infotainment 6 12-05-2012 12:59 AM
FR-S Pioneer Base Unit with bluetooth phone NMMI89 Electronics | Audio | NAV | Infotainment 4 09-18-2012 11:11 PM
