Old 04-29-2014, 08:00 PM   #15
ML
ML's Avatar
Drives: 13 White MT FR-S
I'm running 235/45's on a 17x7 and with tune/decatted/intake, and it will not break loose at all like the stock setup. It kinda makes me sad
Old 04-29-2014, 08:18 PM   #16
RFB
RFB's Avatar
Drives: FRS
A larger diameter wheel may be harder to spin and slow than a smaller diameter same weight wheel thus requiring more power than a stock motor and better brakes (which many of us have anyway {tunes etc.}).
- However -
Rotational mass farther away from center also has a beneficial effect.
Spin a small diameter gyroscope, verses a large diameter gyro. The larger diameter is more stable. The 4 corners of the car - better cornering perhaps ?
CERBERUS
RFB is offline   Reply With Quote
Old 04-29-2014, 09:51 PM   #17
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
CERBERUS
No, less responsiveness. The tires/wheels will resist changes in direction.
FlamingRectumSyndrome is offline   Reply With Quote
The Following User Says Thank You to FlamingRectumSyndrome For This Useful Post:
wu_dot_com (04-30-2014)
Old 04-29-2014, 10:16 PM   #18
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Originally Posted by SirBrass View Post
What about good old canyon carving and some very occassional track, with some ability to slip the back end on turn in (not drifting, just getting the nose pointed around a little faster)?
For spirited driving. The wheel and tire combo is great. There is a reason why the twins have that set up. It's fun. But for grip racing, 215 is not enough in my opinion.
Old 04-29-2014, 10:22 PM   #19
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
autox is different from road course and canyon. You want a bigger tire size
bkblitzed is offline   Reply With Quote
Old 04-29-2014, 10:26 PM   #20
mothespaceman
mothespaceman's Avatar
Drives: 2014 BRZ SWP
But...but... the skinny 17's look so... skinny.
mothespaceman is offline   Reply With Quote
Old 04-29-2014, 11:06 PM   #21
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I was breaking my 255's on 18x9.5's loose with tune, headerback and filter. mmm wonder wonder
Old 04-30-2014, 12:24 AM   #22
ML
ML's Avatar
I didn't say they wouldn't break loose, I said they wouldn't break loose like the stock tires.
Old 04-30-2014, 01:32 AM   #23
shattered_memory
Drives: Satin White BRZ Limited
I don't see anything against a wider wheel and tire set up, but I really do not see the reason to go to 265's or even 255 width tires with stock power. That's just slowing you down, which is FACT. No reason to go past a 245 width tire. Best wheel /tire combo is a 17X9 wheel with 245/40/17 tires. Once you go 255 and beyond, it starts effecting gearing.
shattered_memory is offline   Reply With Quote
Old 04-30-2014, 01:48 AM   #24
Pete156
I like to eat!
um, no. 255 is width, not height. width does nothing to gearing.
Pete156 is offline   Reply With Quote
Old 04-30-2014, 01:58 AM   #25
shattered_memory
you sure? Think about it......just think.
Old 04-30-2014, 02:06 AM   #26
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
i was always under the impression that this car was built with 18s in mind because the wheel wells were so large and our speedometer is off by 2 mph faster than reality. if we have 18s both would be rectified.
SuperDave is offline   Reply With Quote
Old 04-30-2014, 09:39 AM   #27
Tank
Mumbler
Tank's Avatar
Drives: Sensibly
I've noticed many wheels look like they have more of their mass closer towards the center. It's hard to explain without a good picture, but rather than having very long spokes, they have shorter spokes and more of an outer rim that fans out towards the tire bead. Could this be for lowering rotational mass?
Tank is offline   Reply With Quote
Old 04-30-2014, 09:49 AM   #28
RFB
RFB's Avatar
Drives: FRS
Yes - exactly. Less responsive, more stable, less quick to break loose on a corner. The faster the wheel rotates the greater the gyroscopic effect.
Scooters with small wheels are very twitchy and can't be cornered fast while motorcycles with larger wheels can corner very fast and leaned at absurd angles.They don't fall over due to the gyroscopic effect stabilizing the vehicle them up.
In any case the difference between a 17 and an 18 inch wheel is miniscule given the same weight as most end up stock diameter for speedo accuracy, as is the miniscule added gyro effect.
I went from a 20 lb.,17 inch wheel to a 17.25 lb.,18 inch wheel and the larger wheel was more responsive - overall weight methinks should be the greatest concern.
CERBERUS
What are some good slippery narrow tires? PowderfaceTr. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-07-2015 12:14 AM
Orlando Area - Good hotel to stay with girlfriend? Anthony Southeast 15 04-04-2014 02:17 PM
Good deal? Or stay way nmullin11 Scion FR-S / Toyota 86 GT86 General Forum 10 12-14-2013 09:07 PM
FA20CLUB: GOOD REASON TO REMOVE YOUR TURBO KIT RIGHT AWAY.... FA20Club.com Forced Induction 27 06-21-2013 11:19 PM
Is 18 x 7 too narrow Abflug Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-12-2012 10:43 AM
