#15 |
Drives: waiting on a 2021...
There is no camber adjustment with the stock suspension setup. In the front you can run eccentric bolts in the strut to spindle mounts to adjust camber, but the rear has no provision for adjustment.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
#16 |
Drives: 2013 Scion FR-S Whiteout 6MT
As i said, with this small of a drop, there is no need as camber stays in spec, unless u want to add camber...
#17 |
Drives: Firestorm FR-S AT
The springs will be fine on your DD. You are only lowering it about an inch so scraping while daily driving shouldn't be an issue unless you drive on roads with hugely uneven surfaces. Generally you will notice a bit of an increase in ride stiffness, but it is not bone chattering or incredibly uncomfortable.
I run coilovers on my DD, 33,000 miles and climbing. I scrape occasionally coming out of my driveway if I do not take it slow (but then again I am lower than you will be) , but it is the only place I do. |
| Eibach pro kit springs | Fofofawcett | Mid-Atlantic | 27 | 01-29-2014 02:48 PM |
| Eibach Pro Kit Springs | Stierzy34 | Brakes, Suspension, Chassis | 2 | 12-24-2013 09:27 PM |
| Eibach Springs | Astra^EC | AFRICA | 21 | 09-18-2013 04:03 AM |
| Eibach Pro-Kit Springs - NEW IN BOX | Canivideo | Brakes, Suspension, Chassis | 2 | 08-20-2013 08:44 AM |
| Eibach pro kit springs | ihaskrayon | Brakes, Suspension, Chassis | 7 | 07-17-2013 04:28 PM |
