Old 12-16-2013, 05:58 PM   #1
Fofofawcett
Drives: GBS BRZ
Eibach pro kit springs
I am seriously thinking about these springs, as I just some new rims (koning daylights) and would like a small bit of drop. About 1 inch is plenty.
Does anyone around baltimore city have these springs? I've done searches for reviews, but would like to see what they feel like around town and highways here. The stock setup is pretty stiff already, so I am a bit nervous going to a higher rate of spring.
I was wondering if I could get some passenger seat time to make up my mind. Or, just some general impressions would be great too, thanks!
Fofofawcett is offline   Reply With Quote
Old 12-16-2013, 06:56 PM   #2
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
I want a drop too, but I think it's low and rough enough as is. I commute daily through Baltimore City and don't think I could deal with a stiffer ride.
TheseColorsDontRun is offline   Reply With Quote
The Following 3 Users Say Thank You to TheseColorsDontRun For This Useful Post:
Fofofawcett (12-17-2013), Jrohit (12-16-2013), Marcoscrdo (12-17-2013)
Old 12-16-2013, 08:54 PM   #3
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
The price you spend on koni+springs is almost equivalent on coilovers. Food for thought.
I am very insecure. I have no friends. I want people to love me
Old 12-16-2013, 11:58 PM   #4
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
look at the shock dyno's before making any decision. Most coilovers are absolutely terrible with dampening and rebound and just use stiffer springs to try and compensate. Koni is usually very well balanced and is a favorite of scca drivers who arent looking to go with independandt reservoir systems or hydraulic levelers.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
The Following User Says Thank You to Grishbok For This Useful Post:
enwave (12-16-2013)
Old 12-17-2013, 12:07 AM   #5
infinite012
Drives: 13 DGM BRZ Ltd
Why not RCE yellows? They're semi-local to Bodymore.
infinite012 is offline   Reply With Quote
Old 12-17-2013, 06:44 AM   #6
Fofofawcett
Drives: GBS BRZ
Thanks for the responses so far.
Coilovers are probably a bit overkill, as this car is a daily driver and I won't particularly plan on taking it racing (I may at some point, but that situation is more the exception rather than the norm) or lowering that much. It also seems like the general consensus is that, should you go coilovers...it's a whole other level of cost.
I have looked into the rce yellows, and would be open to those and other similar springs.
I've also thought about the koni dampers too, they seem nice, but also may be a bit over the top for my application. That being said, I have heard nothing but good things.
Still, I'd like to get some more impressions on slightly lowering my car and dealing with what passes for roads around Baltimore. I'm not opposed to a stiffer ride, but there are already some cringe worthy moments driving around the city with the stock suspension and 17 inch wheels tires. But, a small drop always looks nice, and my commute is skewed to highways.
Old 12-17-2013, 07:40 AM   #7
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
No they're not. Koni shocks are in the $600 - $700 range and springs are about $300.
You're telling me you can get a decent set of coil overs for <= $1,000? The cheapest coilovers that I consider decent are about $1000 more.
Grimlock is offline   Reply With Quote
The Following User Says Thank You to Grimlock For This Useful Post:
Pure Automotive (12-17-2013)
Old 12-17-2013, 07:43 AM   #8
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
I have the RCE Yellow spring and the Koni shocks. The ride isn't any harsher than stock (more firm, maybe). If you keep the shocks dialed toward the softer end of the spectrum, mine rides just like stock.
I'd offer to give you a ride sometime, but my car still has its Summer tires and there's no way I'm driving it into Baltimore.
Old 12-17-2013, 07:45 AM   #9
Biggins
Drives: Yes
If you're worried about the ride being too rough, I wouldn't change anything. The Prokit and RCE springs are pretty soft and would work.
I'm on stock springs with Konis and a huge sway bar. I keep them dialed to full soft and have no complaints. The sway bar is what makes my car so stiff. I hate driving it on the roads here, but I also hate driving my beater on the roads here too.
Biggins is offline   Reply With Quote
The Following 2 Users Say Thank You to Biggins For This Useful Post:
Fofofawcett (12-17-2013), Pure Automotive (12-17-2013)
Old 12-17-2013, 09:41 AM   #10
Fofofawcett
Drives: GBS BRZ
@Grimlock
Thanks for the insight. I recalled that there was someone around here that had konis and springs and really liked it. So I am guessing the concrete and expansion joints of i97 are just fine with the konis and rce's?
Old 12-17-2013, 09:42 AM   #11
Fofofawcett
Drives: GBS BRZ
Good to know about the sway bar. Did the koni's make a difference at all on stock springs?
Old 12-17-2013, 01:26 PM   #12
Biggins
Drives: Yes
They definitely make a difference on the stock springs, but if I didn't have to follow wacky rules for autocross classing structures, I would have done good coilovers or RCE/Konis instead. They are a huge PITA to install with stock springs. I like having the adjustment capability for autocross, but I'd suggest getting lowering springs with the Konis.
The Following User Says Thank You to Biggins For This Useful Post:
Old 12-17-2013, 01:33 PM   #13
ZionsWrath
Thanks
ZionsWrath's Avatar
Almost equivalent (in price only) to the lowest quality coilovers.
Old 12-17-2013, 01:36 PM   #14
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
The highest quality shocks and springs cost as much as the lowert quality coilovers, why go with low quality over high?
Pure Automotive is offline   Reply With Quote
Eibach Springs Astra^EC AFRICA 21 09-18-2013 04:03 AM
Eibach Pro-Kit Springs - NEW IN BOX Canivideo Brakes, Suspension, Chassis 2 08-20-2013 08:44 AM
Eibach pro kit springs ihaskrayon Brakes, Suspension, Chassis 7 07-17-2013 04:28 PM
$140 Eibach pro kit springs mav1178 Southern California 2 07-12-2013 06:47 PM
FS : Eibach Pro-Kit Springs Brandon86 Canada Classifieds 3 04-17-2013 12:46 PM
