CANADA Canada
View Poll Results: Do you use the shift light?
Yes! Redline only! (performance driving) 34 72.34%
Yes for tame driving only. (fuel economy) 3 6.38%
Not usable... It's not visible and/or loud enough... 5 10.64%
Nope! It's stupid... 5 10.64%
Voters: 47. You may not vote on this poll
Old 04-22-2014, 03:50 PM   #15
Mad_Hatter
Drives: 2013 FR-S 6MT Hot Lava
Originally Posted by 1Cor10:23 View Post
But to be completely honest, best reason to set it high is so you get a fuller sweep on start up
I agree, if it wasn't for the sweep at key-on, probably wouldn't ever bother to set it. I sure can't hear it, and can only really notice it at night.
Mad_Hatter is offline   Reply With Quote
Old 04-22-2014, 03:57 PM   #16
silvercar
silvercar's Avatar
Drives: BRZ Sport tech
Originally Posted by FR-S Guy View Post
I use the shift light for redline and the gear indicator for fuel economy....
Exactly, if you use the gear indicator, you'll see a little arrow appear when it's time to shift (for economy). If you follow it, you'll be in 4th gear going 50km/h (30mph). I have the light set at 7k.
silvercar is offline   Reply With Quote
Old 04-22-2014, 04:05 PM   #17
Muskokan
Drives: white Sport-tech
It dings? I think it's bright enough even in the day to catch your pheriferals ( fuck you for not knowing what I want spell check )
7k here also do I don't hit the limiter
Muskokan is offline   Reply With Quote
Old 04-22-2014, 04:17 PM   #18
ahquit
ahquit's Avatar
Drives: Whiteout FR-S
I set it to 3800 rpm during break in and haven't bothered to change it since then, mostly because I forgot how to do it and I don't pay much attention to it anyways.
ahquit is offline   Reply With Quote
Old 04-22-2014, 04:35 PM   #19
daftpunk
daftpunk's Avatar
Drives: 2013 Scion FRS
Mine is set to 3500 to make sure I don't rev too high while the engine isn't properly warm.
I live about 2 minutes from the highway so it's cold start to 100+km/h within a matter of minutes.
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 04-22-2014, 04:45 PM   #20
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
I've got mine set to 7200. There is already a built in shift light for economy. If you display your gear in the digital display you can also make it so that a little arrow flashes when it is best to shift for economy. It is a lot more accurate than you guessing because it has actually been programmed into the ECU and the shift lift flashes at different RPM depending on what gear you are in
ToyoburuBRZ is offline   Reply With Quote
Old 04-22-2014, 04:46 PM   #21
ToyoburuBRZ
Drives: Black BRZ
Originally Posted by mabviper View Post
Awesome! So most of you do set it high. I myself have it at 7k. I had it to 7.2k before but I kept hitting the limitter, lol. What does bug me is that when I go autocross and/or track, it's barely noticable. I can't see it let alone hear it w/ a helmet
I do wish it was louder as well. I am sure someone will come out with an aftermarket solution for this.... its just a little buzzer behind the dash I am assuming. cant be that hard to change
Old 04-22-2014, 04:59 PM   #22
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I wish it was louder AND brighter. It would be much more useful that way.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 04-22-2014, 05:01 PM   #23
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
i didn't know it made noise....
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 04-22-2014, 05:06 PM   #24
1Cor10:23
1Cor10:23's Avatar
Could be wrong but IIRC it's an option to set beep on or off, same menu that you use to set the sweeper / light itself.
Old 04-22-2014, 05:35 PM   #25
chas3wba0
chas3wba0's Avatar
Drives: Yes
Verified. After setting the RPM at which the light comes on, you are asked to toggle the audible beep on or off
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
1Cor10:23 (04-22-2014)
Old 04-22-2014, 06:36 PM   #26
DR 86
DR 86's Avatar
Have it set to 7000, mainly just for the sweep. With my tune by Moto-east, I have a really soft rev limiter, so I don't really "bounce" off it at redline, so I can hold redline for a second or two...really sweet.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 04-23-2014, 07:43 AM   #27
Skurj
Drives: SOLD...
I'm too busy looking where I'm going...
Should add one more option to the list.. "What shift Light?"
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 04-23-2014, 08:44 AM   #28
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
The shift light is for approaching the redline. There is already a fuel economy shift up indicator on the multi function display.
I set my shift light to 7000rpm.
The Casio beep at redline isn't really audible with the music on.
krayzie is offline   Reply With Quote
After Market Shift Light Toyota GT 86 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-01-2015 08:29 PM
No shift light after cai installed v86 Engine, Exhaust, Transmission 7 03-27-2014 04:22 AM
86 Shift Light Martin Donnon Engine, Exhaust, Transmission 7 08-17-2013 03:34 AM
Shift light for gt86 Toyota GT 86 Electronics | Audio | NAV | Infotainment 9 05-08-2013 12:42 PM
Shift light. Style Scion FR-S / Toyota 86 GT86 General Forum 24 07-19-2012 03:19 AM
