#15 | |
Drives: 2013 FRS Whiteout
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#16 |
Drives: Sterling BRZ Ltd
Thanks
The heat shield is mounted to the pipe, there are two small female threaded bungs on the bolt so small bolts go through the shield. Nothing goes inside the pipe. The oil cooler is mounted to a brackets thats welded to the front bumper bar.
| The Following User Says Thank You to mrk1 For This Useful Post: | yomny (02-05-2015) |
#17 | |
However, under constant airflow, it'll shield the piping from engine bay heat, and allow your intake charge to be cooler, since it's absorbing less heat. Overall, it's usually better to have it. |
#18 | |
The only time I can see this being an issue is at drag strip when you wait in line forever and then all of a sudden floor the crap out of the car. Even then you will quickly have the air flow back in the picture.
| Sprintex blower heat soak | evan | Northwest | 2 | 03-20-2014 10:50 PM |
| DIY Gold Foil heat wrap intake box | autoCAR | DIY (Do-It-Yourself) Guides | 35 | 02-20-2014 02:22 PM |
| TRD Intake and sound tube? | kALMIGHTY | Engine, Exhaust, Transmission | 9 | 09-13-2013 05:46 PM |
| Intake tube, or CAI? | Matt90 | Engine, Exhaust, Transmission | 17 | 08-29-2013 08:58 AM |
| intake tube | mrnibbs | Engine, Exhaust, Transmission | 7 | 07-13-2013 02:31 AM |
