Old 02-05-2015, 01:41 PM   #15
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
To add onto this, the airflow in the intake tube is only there for a moment, but the total mass of air going through the intake tube is pretty substantial compared to the amount of space there.
Even if the intake charge temp goes up 1F from soaking from the intake tube, the tube itself is being cooled by the intake charge absorbing that heat, and the tube will cool down quickly.
Your observations are dead on!
So this tube would benefit from some sort of shielding/insulating in those cases where the downpipe heats it up while standing?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-05-2015, 01:43 PM   #16
mrk1
Drives: Sterling BRZ Ltd
Thanks
The heat shield is mounted to the pipe, there are two small female threaded bungs on the bolt so small bolts go through the shield. Nothing goes inside the pipe.
The oil cooler is mounted to a brackets thats welded to the front bumper bar.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
yomny (02-05-2015)
Old 02-05-2015, 01:45 PM   #17
CSG Mike
CSG Mike's Avatar
It's a double edged sword for street driven cars. If you sit for a long time, the piping will still get up to the same high temp, and the shielding/insulation will also add to the total amount of heat in the system, causing it to cool down slower.
However, under constant airflow, it'll shield the piping from engine bay heat, and allow your intake charge to be cooler, since it's absorbing less heat.
Overall, it's usually better to have it.
DylanJZA (09-23-2022), yomny (02-05-2015)
Old 02-05-2015, 01:46 PM   #18
mrk1
Standing is a different scenario. Less air flow over all and also less flow through the pipe. So yes the pipe will heat soak. However it doesn't matter as much, if your IAT rises at idle it isn't going to harm anything, your just idling. High IAT's are bad under boost and at high loads when there are more stress's on the engine.
The only time I can see this being an issue is at drag strip when you wait in line forever and then all of a sudden floor the crap out of the car. Even then you will quickly have the air flow back in the picture.
The Build Thread
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
CSG Mike (02-05-2015), DylanJZA (09-23-2022), yomny (02-05-2015)
Sprintex blower heat soak evan Northwest 2 03-20-2014 10:50 PM
DIY Gold Foil heat wrap intake box autoCAR DIY (Do-It-Yourself) Guides 35 02-20-2014 02:22 PM
TRD Intake and sound tube? kALMIGHTY Engine, Exhaust, Transmission 9 09-13-2013 05:46 PM
Intake tube, or CAI? Matt90 Engine, Exhaust, Transmission 17 08-29-2013 08:58 AM
intake tube mrnibbs Engine, Exhaust, Transmission 7 07-13-2013 02:31 AM
