Old 03-31-2014, 12:13 PM   #15
puma
crew chief
puma's Avatar
Drives: Race car FR-S
I will correct this yet again. The supercharger kits don't make linear power. They make linear boost plots and the power plots are peakier and less linear than a turbo with a flat torque/boost curve.
would a supercharger produce less under hood heat than a turbo as this is a big concern for me?
puma is offline   Reply With Quote
Old 03-31-2014, 12:19 PM   #16
jamesm
turbo placement has very little if anything to do with overheating issues. cooling system components and fan configuration are both far more important. if you don't want overheating issues, upgrade all of the stock components, add an oil cooler, and keep at least one stock fan. i'm not suggesting that the turbo location doesn't matter *at all*, just that it matter far less than those other factors.
The Following User Says Thank You to jamesm For This Useful Post:
diss7 (04-04-2014)
Old 03-31-2014, 12:35 PM   #17
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by ptuning View Post
If you look at our S2000 low-mount turbo system, you'll find that it is one of the few systems on the market that can successfully complete an all out 30 minute HPDE session without the need for a vented hood, excessive heat insulation of exhaust components, and major relocation of other heat sensitive components. Turbo location goes a long way in taming under hood heat.
- Toan
Art.
The Following User Says Thank You to sw20kosh For This Useful Post:
ptuning (03-31-2014)
Old 03-31-2014, 12:50 PM   #18
bjun
bjun's Avatar
Drives: white premium brz M/T
My main reason purchasing the PTuning kit was the turbo placement. Since it is a low mount less heat is created under hood. And I can tell you from experience because I drove 26hours straight nonstop with the ptuning kit from ptuning virginia to back home in texas. No heating issues during the whole trip
bjun is offline   Reply With Quote
Old 03-31-2014, 12:53 PM   #19
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
You're gonna need crazy cooling to track or race FI with this car. CRAZY cooling!
Old 03-31-2014, 01:04 PM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Eurasianman View Post
OP, you might need to look into a different vehicle then :\
If vented hoods are not allowed in the racing series he is in (which seems weird to me), then there are plenty of other methods of venting the hot air in the engine compartment.
Old 03-31-2014, 01:06 PM   #21
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yes it will. Don't forget that in a whp/torque based class of racing where only peak numbers are factored in that area under the curve is where you can win the race. Turbos can make that peak torque number way lower in the RPM range and give you a ton more area under the curve.
Old 03-31-2014, 01:07 PM   #22
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
450+WHP on E85 with 80*F ambiant temps today. I was in boost more than i should have been on public mountain roads at 3,000 feet ASL. STOCK radiator, NO oil cooler, No vented hood. No over heating. 8 quart MAP oil pan running amsoil dominator 10w-30 and windshield wiper cowl removed. Ceramic coated and dei titanium wrapped.
Old 03-31-2014, 01:07 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I took many hour long trips with the Full Blown kit. Those aren't the conditions where the cooling system is going to struggle.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
bjun (03-31-2014), wparsons (03-31-2014)
Old 03-31-2014, 01:08 PM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
This would be one of those ways to help vent the heat under the hood.
The Following User Says Thank You to King Tut For This Useful Post:
Reaper (03-31-2014)
Old 03-31-2014, 01:09 PM   #25
Reaper
Reaper's Avatar
Drives: violent
remove the cowl!
The Following User Says Thank You to Reaper For This Useful Post:
King Tut (03-31-2014)
Old 03-31-2014, 01:12 PM   #26
bjun
bjun's Avatar
True. Conditions are different in a race but on the way back I did have fun boosting here and there. Just giving my opinion on the low mount saying that it might help since he cant vent out air
Old 03-31-2014, 01:12 PM   #27
puma
crew chief
puma's Avatar
actually i beleive most racing series don't allow a vented hood, the cars need to look like a car from the factory. I don't even remember seeing a serie in which they were allowed, grand-am, continental tire, etc, none can add aero type of mod other than a front splitter and a rear wing (sometimes, not in the lower class)
Old 03-31-2014, 01:14 PM   #28
puma
crew chief
puma's Avatar
yeah that's right, a turbo would produce more power under the curve which isn't taken into account.
I guess ptunning would be the best bet but damn it's expensive.
Race gas? feldy Engine, Exhaust, Transmission 70 08-20-2014 06:20 PM
86 to Race inaugural Moder Sports Car Race 000 Racing AUSTRALIA 4 05-23-2013 06:22 PM
Race It Up! Wolfking Scion FR-S / Toyota 86 GT86 General Forum 11 02-24-2013 06:01 PM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 08:51 PM
