Old 03-28-2014, 01:37 AM   #15
toeout
You need to bring the steering wheel closer, no other way around it. I had a 2001 Accord with the most hateful ergonomics. Momo steering wheel with 90mm dish solved my problem.
Uncomfortable seating position will be in the back of your mind every time you drive, not worth putting up with it.
toeout is offline   Reply With Quote
Old 03-28-2014, 07:19 AM   #16
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
I have the same problem. 6'6 and just fit. No space for a helmet. Might have to take the time at some point and remove the seat to see what can be done.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 03-28-2014, 09:07 AM   #17
Model Citizen
Lacking brains
Drives: frz
Originally Posted by csworldfan View Post
So this is my issue... My knee is just too Damn close to the steering wheel. This is with the seat all the way back, and lowered. Any suggestions?
Not sure how much just being lower would help, would that just point your thigh at a lower angle?
Stock seats already go basically against where the floor rises in the rear iirc. I may be wrong though.
Model Citizen is offline   Reply With Quote
Old 03-28-2014, 09:54 AM   #18
csworldfan
Is there any way to get a spacer for the stock wheel? I'd like to retain the airbag.
csworldfan is offline   Reply With Quote
Old 03-28-2014, 09:56 AM   #19
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Cut your feet off? I feel like thats what I have to do...
supramkivtt2jz is offline   Reply With Quote
Old 03-28-2014, 10:33 AM   #20
Luis_GT
You never mentioned if you moved the steering wheel, did you put it at the highest position and pulled it closer to your chest (Some people don't know the steering wheel is telescopic)
Old 03-28-2014, 12:06 PM   #21
csworldfan
Steering wheel is as high and as far back as it goes.
Old 03-28-2014, 05:16 PM   #22
brzr
brzr's Avatar
Drives: 2013 frs
what if you put it up high, and pull it out instead of back?
brzr is offline   Reply With Quote
Old 03-28-2014, 05:33 PM   #23
forzajuve
Drives: Ultramarine 86 - 6MT
Get to choppin`
forzajuve is offline   Reply With Quote
Old 03-29-2014, 01:57 AM   #24
csworldfan
That's what I meant, sorry. It's as close to me as possible.
Old 03-31-2014, 05:40 PM   #25
StuAU
Drives: 86 GTS
Is it possible to remove the seats height adjustment mechanism? That should give you another inch.
StuAU is offline   Reply With Quote
Old 04-04-2014, 01:49 PM   #26
Imsteak
Drives: Whiteout FrsMono MT, E63
Originally Posted by Model Citizen View Post
I'm about 6'3" with a long torso, I fit terribly in small cars. I made the leap into this one because the headroom was just bearable in stock form and at the time it looked like the damotorsports solution was on the horizon. They went radio silent on the product and I started on trying to find my own solution.
Springs stretched and the plastic ties that bind them cut did help, not enough to clear a helmet however.
This is what I ended up doing, and it has been fantastic. Gf needs a booster seat to drive the car comfortably now (she's averageish height 5'7" or so). Shorter people that sit in the car can barely see over the wheel. The seat pan is basically sitting on the floor and thanks to the scooped design of the base just about all the headroom that can be gained is.
http://www.ft86club.com/forums/showthread.php?t=46801
Is your issue slouching for headroom that's causing knees into the wheel?
Hey Got a question on spring stretch and plastic bind. What do you mean by that. I am 6'2 and I think lower half inch will clear me of the helmet I have
Imsteak is offline   Reply With Quote
Old 04-04-2014, 01:54 PM   #27
Model Citizen
Lacking brains
Drives: frz
Look under the seat
You'll see
Someone listed a base pic in one of the threads.
The Following User Says Thank You to Model Citizen For This Useful Post:
Imsteak (04-04-2014)
Old 06-21-2016, 02:52 PM   #28
SupaDave
Drives: 2013 Silver Scion FRS
I know this is a pretty old thread but did anyone get a clear answer for the riddle of the tall man for the seats?
SupaDave is offline   Reply With Quote
Lumbar support for seats? My lower back is killing me Indestruct Cosmetic Modification (Interior/Exterior/Lighting) 65 05-18-2017 11:56 AM
Scion FRS Stock Full Seats (Driver / Passenger / Rear seats) for sale Sehwan Kim Interior Parts (Incl. Lighting) 1 01-28-2015 07:35 AM
lower stock seats? choi0706 Cosmetic Modification (Interior/Exterior/Lighting) 5 07-26-2013 06:52 PM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 06:45 PM
Lower the seats? MrMista Scion FR-S / Toyota 86 GT86 General Forum 11 04-19-2013 07:41 PM
