Old 03-22-2014, 10:50 AM   #15
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
What is your power goal ? What's the offset and tire sizes you will run ?
adprokid is offline   Reply With Quote
Old 03-23-2014, 07:54 PM   #16
Jhon19lopez
Drives: 2013 scion fr-s
i just bought a ls3 create from gm so hopefully by the end of the year ill make that happen,offset is unknown use the be 18x9.5 + 7 , and 18 x 10 + 13 i added 6 inch lips up front and 7.5 in the rear and tire size will be 225/40/18 , 275/40/18
Jhon19lopez is offline   Reply With Quote
Old 03-23-2014, 08:20 PM   #17
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Thats a beast project
best of luck
Old 03-23-2014, 08:50 PM   #18
Vten
Drives: Too heavy
225/40 on a 11.5" wide wheel ?? Damn sir , you're my new superhero !
Vten is offline   Reply With Quote
Old 03-23-2014, 09:55 PM   #19
xwd
225/285? Really? SMH.
Old 03-23-2014, 10:29 PM   #20
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
I can't believe people are still doing this shit
XanRules is offline   Reply With Quote
Old 03-23-2014, 11:06 PM   #21
mashal
DADA
mashal's Avatar
Drives: 2013
Please do post pictures after tire install.
mashal is offline   Reply With Quote
Old 03-24-2014, 07:53 AM   #22
cncnjn
Drives: Raven FRS Veilside Nissan 350z
Damn..
cncnjn is offline   Reply With Quote
Old 03-24-2014, 07:55 AM   #23
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
I like dis
you have rims that are wider than some peoples rims are in diameter.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-24-2014, 09:04 AM   #24
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
LS or not, you bust on that wheel setup. Such a shame.
slicktop is offline   Reply With Quote
Old 03-24-2014, 10:39 AM   #25
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Looking forward to seeing this
Flat Black VW is offline   Reply With Quote
Old 03-24-2014, 11:07 AM   #26
xwd
It would only really look decent with a custom rear setup with a tubbed chassis and custom rear end/axles/etc. Having them stick out or running like -8 degrees of camber is beyond dumb.
Old 03-24-2014, 11:43 AM   #27
dmarkey
Originally Posted by dmarkey View Post
I'm surprised nobody is running super wide wheels with these kits. I'm on a 9/10 setup under stock fenders, and based off the added width of the kit you could easily go another 3" wider. I'd love to see someone do one of these with an 11" front and 12" or larger rear and some 3xx width tires... now THAT would be wild. :P
Glad to see someone doing this on the wide fender flares (especially in NC)! Now if only we could convince you to run these tires in 285/30-18 and 335/30-18...
dmarkey is offline   Reply With Quote
Old 03-24-2014, 11:48 AM   #28
Deadspool
Much title. Wow.
Deadspool's Avatar
That looks like a mortgage payment to me.
Wheel Directory: Porsche Turbo Twist II 18x10.0 +15 /18x11.0 +25 SLICVIC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 84 05-31-2016 12:36 PM
rebuild works vs-xx 18x13.5 Jhon19lopez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 12-16-2013 03:13 PM
CCW C10 Wheels 18x11 and 18x12 Carolina Dyno Wheels and Tires 0 12-11-2013 01:19 PM
P&L Header Dyno and Fitment test-With my Vortech Test Kit Huehuecoyotl Engine, Exhaust, Transmission 118 07-07-2013 10:26 PM
