#15 |
Drives: ZN6 / GDB-G
What is your power goal ? What's the offset and tire sizes you will run ?
#16 |
Drives: 2013 scion fr-s
i just bought a ls3 create from gm so hopefully by the end of the year ill make that happen,offset is unknown use the be 18x9.5 + 7 , and 18 x 10 + 13 i added 6 inch lips up front and 7.5 in the rear and tire size will be 225/40/18 , 275/40/18
#17 | |
Drives: ZN6 / GDB-G
![]() best of luck |
#18 |
Drives: Too heavy
225/40 on a 11.5" wide wheel ?? Damn sir , you're my new superhero !
#19 |
225/285? Really? SMH.
#20 |
A Very Powerful Wizard
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
#21 |
DADA
Drives: 2013
Please do post pictures after tire install.
#22 |
Drives: Raven FRS Veilside Nissan 350z
Damn..
#23 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
I like dis
you have rims that are wider than some peoples rims are in diameter.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
#24 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
LS or not, you bust on that wheel setup. Such a shame.
#25 |
Drives: 2013 Subaru BRZ
Looking forward to seeing this
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#26 |
It would only really look decent with a custom rear setup with a tubbed chassis and custom rear end/axles/etc. Having them stick out or running like -8 degrees of camber is beyond dumb.
#27 | |
#28 | |
Much title. Wow.
That looks like a mortgage payment to me.
| Wheel Directory: Porsche Turbo Twist II 18x10.0 +15 /18x11.0 +25 | SLICVIC | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 84 | 05-31-2016 12:36 PM |
| rebuild works vs-xx 18x13.5 | Jhon19lopez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 12-16-2013 03:13 PM |
| CCW C10 Wheels 18x11 and 18x12 | Carolina Dyno | Wheels and Tires | 0 | 12-11-2013 01:19 PM |
| P&L Header Dyno and Fitment test-With my Vortech Test Kit | Huehuecoyotl | Engine, Exhaust, Transmission | 118 | 07-07-2013 10:26 PM |
