#15 | |
Drives: Toyota FT/MT 86
| The Following User Says Thank You to dssence For This Useful Post: | retrosmiths (03-17-2014) |
#16 |
Drives: Scion FR-S Whiteout
You rang?
2013 Scion FR-S
#17 |
It's difficult to make the LED strips bend to accomodate the chrome assembly design, FYI.
2013 Scion FR-S
| The Following User Says Thank You to retrosmiths For This Useful Post: | dssence (03-16-2014) |
#18 | |
. I did really like your mod on your enclosure. I bought some led strips with high intensity SMD leds. Initially I was trying to find some led strips with a led motion but couldn't find any. If I'm not mistaken the leds on the GT when they light up have some motion. So you had to heat up the casing remove it and attach the leds inside. I really don't want to go thorough all that. By anyways.. just give me a couple tips. I really like your mod. It's really neat and decent that's what I want mine to look like. I'm in argentina
#19 | |
Listen I wanted to see your progress on dropbox but it's empty no pictures. Do you have another link. And I was thinking on sticking the led strip with some rigid wire for placement. until I finally find the position. Did you stick it onto the chrome reflector or on the top casing?. can you upload a vid to youtube would be great ! |
#20 |
hosld on, I'm drunk
2013 Scion FR-S
| The Following 2 Users Say Thank You to retrosmiths For This Useful Post: | jonzhuxD (03-16-2014), Turbo95eg6 (03-16-2014) |
#21 |
Do Argentine vehicle laws allow you to add flashing lights to your car? That would not go over well here. Another reason I'm glad I have the boring old '13 FR-S. I can't wait to see how badly they screw up the looks of the next generation FR-S/BRZ with idiotic bling.
| The Following User Says Thank You to Tromatic For This Useful Post: | dssence (03-16-2014) |
#22 | |
What's that about the old '13 FRS? . you do think they're screwing up in the next generation FRS? . I'm not sure if the GTs has that led strip with moving leds |
#23 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Our cars better not be the next Knight Industries K.I.T.T.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
| The Following User Says Thank You to DaJo For This Useful Post: | dssence (03-16-2014) |
#24 | |
Not sure but I think i've seen the 86 GT that kind of strip have some kind of movement when it turned on maybe i'm mistaken. Or was just my impression. |
#25 | |
Drives: Ultramarine FR-S
Which is why there's a flicker in the lights you've seen in videos and whatnot, they do not flicker in person. http://www.car4play.com/forum/post/index.htm?t=9925 |
#26 |
ProCrastinationConsultant
^ that's called Pulse Width Modulation, or PWM for short.
| The Following User Says Thank You to soundman98 For This Useful Post: | DaJo (03-16-2014) |
#27 |
Sorry for the late reply guys, I was hungover as crap and still am.
I bought them LED strips from superbrightleds.com and just tapped them directly to the signal lights. HOWEVER, it may not be a good idea cause I noticed the driver side LEDs subtly less brighter than the passenger side. I'm guessing it could be because it's farther away from the battery or something, so I would recommend a relay harness. I baked them lights open because there is no way I can cleanly install them from the bulb hole and you might actually end up scratching the inside of the glass lens. It's not too hard, 250F for 8-10 minutes in the oven would do the trick. Also, I fabricated a mount for the LEDs from sheet metal, it's just a bit wider than the strips themselves, so that I can position the strips further down, otherwise if you just stick em in the chrome assembly, it will be partially covered by the hood. I'll post a pic when I find it later today. Sent from my Nexus 5 using Tapatalk
2013 Scion FR-S
#28 | |
I will install them on the parking lights bulb not turn light signal as you did. So when I turn the knob of the backlight of the gauges it will light up that bulbs. I Don't know if it's called parking light or whatever it is. DRL I think it's the only bulb next to the High beams halogen bulb. So I want to know for sure what's the best way to install these led strips without blowing everything up. Anyone !?? |
| ---Autolismo.com, Vancouver Canada--- Trunk LED Bulb and Strip | autolismo | Interior Parts (Incl. Lighting) | 314 | 11-14-2017 01:02 PM |
| BRZ LED Strip in Headlights (bulb) | R0ME0 | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 05-27-2014 12:57 AM |
| DIY Trunk light mod with L.E.D. strip | chrisbfrs | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 01-16-2014 12:34 PM |
| Fuse for parking/fog lights | Bg8780 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-27-2013 09:17 PM |
| Fuse # to the Fog light's | 914_WHITE_FRS | Issues | Warranty | Recalls / TSB | 3 | 08-06-2013 04:40 PM |
