Old 03-16-2014, 10:11 AM   #15
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
It sounds like you have several things going on.
First, it is a fact that even if you are in drive, the paddle shifters will work.
The revs staying higher than normal sounds like sport mode where gears are selected by the transmission to maximize power while in drive. If you aren't driving aggressively, it will seem weird in the way that the transmission is behaving.
When you say it was showing speed, do you mean showing in the digital speedometer or on the analog speedometer? The tachometer I expect to see something, but, if either speedometer is showing speed when there is none, it sounds like something is not working right. Although the speed sensor is usually something pretty simple and robust (it is rare for it to fail).
Not to sound disrespectful, but, have you compared what you are experiencing to what the owners manual says? If the car is not behaving like it is supposed to according to the manual then you can explain that to the dealership. Otherwise, it does not make sense. It is best to arm yourself with the knowledge in the owners manual. At the least, you will be better able to explain what is going on.
Demandred7 is offline   Reply With Quote
Old 03-16-2014, 10:30 AM   #16
lorip713
Originally Posted by Burrcold View Post
There probably is nothing wrong then. Besides, if you explained it to them the way you did here, they probably wouldn't know what to look for. Did you ask to go for a test drive with the service tech to show him the issue?
I asked if I could speak to the service tech but they told me that everything I described sounded normal and the tech couldn't find anything wrong.
lorip713 is offline   Reply With Quote
Old 03-16-2014, 10:35 AM   #17
lorip713
Not to sound disrespectful, but, have you compared what you are experiencing to what the owners manual says? If the car is not behaving like it is supposed to according to the manual then you can explain that to the dealership. Otherwise, it does not make sense. It is best to arm yourself with the knowledge in the owners manual. At the least, you will be better able to explain what is going on.[/QUOTE]
Speed shows on the digital speedometer. Just this morning, I slow to take a corner behind another car and the speedometer showed I was still doing 25. No way. The car in front of me almost came to a complete stop even though we had the right of way and no stop sign.
Old 03-16-2014, 10:38 AM   #18
lorip713
Then when I accelerated again, all of a sudden the speedometer says I'm doing 45 and you can hear the engine revving.
Old 03-16-2014, 10:39 AM   #19
Burrcold
Drives: Subaru BRZ Limited
Demand that they come with you on a test drive. If you are COMPLETELY stopped, your speedo should not be showing anything other than 0 mph.
The Following User Says Thank You to Burrcold For This Useful Post:
lorip713 (03-16-2014)
Old 03-16-2014, 10:40 AM   #20
Burrcold
Go to a different dealer. This is an obvious problem.
Old 03-16-2014, 10:17 PM   #21
Demandred7
Demandred7's Avatar
Your car sounds possessed. Should be pretty obvious to the tech if they go for even just a test drive around the corner. Obviously they have dismissed you prematurely. If they don't, hopefully you have the ability to go to a different dealer. Hopefully it didn't sound like I thought you were on crack, your situation seems unusual but definitely a legitimate problem with your car.
Old 03-16-2014, 10:49 PM   #22
captain_beebus
captain_beebus's Avatar
Drives: '14 Firestorm FR-S
Intermittent problems like that suck. Good luck getting the tech to try and chase something he doesn't even know actually exists.
captain_beebus is offline   Reply With Quote
Old 03-17-2014, 07:30 PM   #23
lorip713
Thanks everyone. I'm going to make another appt to rake the car in. I thought maybe the car was finally "broken in" at 10k miles and was now acting "normal." I've had problems with the windows needing to be reinitialized, there's a TSB fir that, and reported it 3 times before they issued the TSB, so figured maybe this is something else Toyota doesn't know about yet
Old 03-17-2014, 09:25 PM   #24
Tromatic
Any other FR-S/BRZ owners near you you could have ride along with you for a test?
Tromatic is offline   Reply With Quote
Old 03-17-2014, 09:33 PM   #25
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Is it possible that your digital speedo is reading in KPH instead of MPH right now? That would account for the #s being weird...otherwise sounds like sport mode. Maybe try and reset the ecu...
Fett4Real is offline   Reply With Quote
Old 03-17-2014, 09:37 PM   #26
stugray
Drives: 2013 GBS BRZ Limited
It sounds like your speed sensor (I believe it is in the differential) is reading incorrectly.
In an Auto trans, the brain needs that speed sensor to operate the tranny.
If it is confused it could act strangely as you describe....
Old 03-17-2014, 09:44 PM   #27
NickFRS
Drives: 2013 Asphalt FRS
Go to a service manager. Say you want to test drive an auto on the lot to make sure your car reacts the same way because your car is having issues and his tech's are blind siding you about it. Go for a drive WITH HIM in their car. Then take him for a ride WITH HIM in your car. If it's different have him give you a rental so they can see whats going on.
^ This is the logical way of going about things at a dealership.
If they refuse call SOA or go to a different dealership.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 03-26-2014, 02:12 PM   #28
stugray
Any word on what happened?
Teaching to drive manual frs bdanisi Scion FR-S / Toyota 86 GT86 General Forum 45 09-01-2013 04:35 PM
Want to test drive Manual FR-S or BRZ... Ann Arbor Nourdmrolnmt1 Great Lakes 5 11-25-2012 10:42 PM
How's the drive using traffic? Manual tranny only gunmetal5 Scion FR-S / Toyota 86 GT86 General Forum 32 10-26-2012 03:21 PM
How to drive manual pezzie AUSTRALIA 35 08-17-2012 08:41 AM
Where to learn how to drive manual.... Saibot CANADA 12 03-13-2012 06:28 PM
