#15 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Any alteration to the main ignition and fueling tables will make for a rough transition from on/off throttle. With RaceROM we can make a custom map that is only active in a certain range, only for a certain time, and only when desired. That is why we can enable this without messing up cruise and low load operation and trims. Otherwise if you tweak the primary fueling and timing tables (or enrichment) you get sideffects that make for a lousy ride. Been there done that with the MX5 where we don't have custom maps (yet....), so this is a FT86/GTR only feature.
#16 |
Thupercharged
The next time I send in logs I'm going to request this... for science and stuff.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#17 |
The Mechanic
Drives: Civic Turbo,FR-S
i only see the ignition tables go to .15 and theres no way to adjust the break points on it. closed loop goes ~.08 always a steady 32 degrees. how would i go about changing closed loop timing?
#18 |
Drives: 2013 FRS
You can adjust load and rpm breakpoints in Rom Raider. In Tuner Pro, I never bothered to defined them individually since it didn't seem necessary or useful at the time. For maximum pop-age, you'd want to run negative timing during over-run and try to delay deccel-triggered fuel cut. Basically making the ECU control fuel/spark like ECUs did 10 years ago before emissions required them to get clean. It's all do-able and shouldn't require any custom maps.
#19 | |
The Mechanic
#20 |
Drives: 2015 WRX
Have any of you guys seen an muffler burst from backfires or had to replace a muffler due to the packing being ruined from constant over fueling? I'm honestly surprised a tuner would intentionally tune this into a tune as it serves no practical purpose other than wasting fuel and potentially causing exhaust damage.
#21 | |
Drives: 2013 Asphalt FR-S
As for the timing.. you will need to setup the map with the first load column being a little uder the decel load you see and the next column just over the decel load so you can run negative values in the first column and normal values in the second so your not trying to cruise at low load with retarded timing values. Just had another thought, you might run into some idle / low fuel trim issues if you turn off decel fuel cut.. keep an eye on them and see. You could always force open loop at decel load values and that might allow you to play around with how much fuel etc you have during decel, you will need to modify the load axis of the fuel tables as well as the closed loop fueling target compensation A&B tables (set them to 14.7 where you want open loop). But that might require you to zero out the cl-ol timers and transition based on fuel map values.
~Namaste~ Last edited by mad_sb; 03-11-2014 at 08:33 AM. |
#22 |
Wouldn't this also increase EGT? Increased potential of burning/melting cats?
#23 |
The Mechanic
what cats? lol
#24 | |
Thupercharged
2013 FRS
#25 |
Thupercharged
Im a dog person myself....
2013 FRS
#26 | |
The Mechanic
#27 |
Señor Member
Drives: BRZ SWP
wow. great discussion going on. did some testing. I changed the ignition advance base timing A map to neg 10 degrees on the first column (,15) and the base idle (above speed threshold) to negative timing. lots of pops at partial throttle. lots on downshift and a couple on hard shifts. I'm gonna fine tune it a bit more so I don't have to play with the throttle so much to get the pops.
Sent from my SGH-I337M using Tapatalk |
#28 | |
Thupercharged
2013 FRS
| Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1213 | 06-17-2025 04:02 PM |
| R/T Tuning & R/T Tuning Speed Shop Review Thread | R/T Tuning | User/Vendor/Sponsor Reviews, Feedback, Comments | 37 | 10-03-2014 02:23 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 02:12 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
