Old 04-02-2019, 03:12 PM   #15
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I get the front end up and jack stand set, open the Fumoto valve, then go back to the jack and slowly lower it to just over the top of the drain pan, which makes the car close to level. Then back up again to close the valve and back down to fill. Reading this thread made me realize I've been making a lot of unnecessary work for myself.
Qwimby1 is offline   Reply With Quote
Old 04-02-2019, 03:19 PM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
If all I'm doing is oil change, I just drive on my rhino ramps. 15 minute job. If I'm also rotating tires, I break out the Quickjack.
Old 04-02-2019, 03:34 PM   #17
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I used to do oil changes in a driveway and I would back in and drive the front onto these low cheap ramps from amazon, car would sit pretty level for draining. This made a super easy and simple way to drain the oil out.
I now have a flat garage and I still just drive the front on small ramps and use a jack to unscrew the oil plug and then lower it back on the ramps. Seems to work really well. I did let it sit for a while to let it drain as much as possible. It does drain while the front is slightly raised from the ramps.
I would not let the car drain with just one end on jackstands, at that point use some cheap low profile ramps/or boards that are only 4-5 inches tall, get a better drain. That or get it on all 4 jackstands.
DandoX is offline   Reply With Quote
Old 04-02-2019, 07:45 PM   #18
qqzj
Drives: MDX, Camry
I always thought rhino ramp is too steep. Do you have a picture of the car on the ramp?
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 04-02-2019, 08:38 PM   #19
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Not with the twin, but this car. Not enough angle to matter. Ramps are easy and safe. Plus I think every car i have recently had on ramps, the drain plug was on that side. Extra drainage.
Old 04-02-2019, 09:34 PM   #20
new2subaru
Weight Weenie
Drives: 15 FR-S
Diggin the work boots
The Following User Says Thank You to new2subaru For This Useful Post:
VIP BRZ (04-02-2019)
Old 04-03-2019, 12:45 AM   #21
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Yea, my youngest son is a dork, just like his old man.
new2subaru (04-03-2019)
Jack Stands + Pinch Weld Wyattkb Scion FR-S / Toyota 86 GT86 General Forum 36 10-12-2015 04:45 AM
Car's sitting on jack stands while waiting for new wheels. hanabie DIY (Do-It-Yourself) Guides 9 02-08-2014 03:03 PM
Jacks/stands around central nj? Reflex NY / NJ / CT / PA 9 09-13-2013 12:30 PM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 05:43 PM
The S in September stands for Suspension! Lots of Sales! KronosPerformance Brakes, Suspension, Chassis 8 09-13-2012 03:08 PM
