Old 03-02-2014, 05:34 PM   #15
white86out
Originally Posted by DAEMANO View Post
@white86out
The above is true for a car at stock height, however if you plan on lowering the car much at all, the minor "poke" of an et35 will camber in nicely to flush. If you pick higher offset (et45) and lower the car the tires will "suck" in due to the same natural camber. Keep this in mind.
Makes sense, maybe I'll go with the also available +38 just to be safe. I'm sure if the +35's go flush, than and extra 3 wont look too sucked!
white86out is offline   Reply With Quote
Old 03-03-2014, 02:10 PM   #16
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
When you get those bolted on, post photos and specs in a new topic in this forum area so I can add that spec to the Wheel Directory. Thanks!
Old 03-03-2014, 02:30 PM   #17
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by swilliams View Post
Look at the pics in this thread. You can really see the poke on the black FRS. If you like the look of those cars, there's your answer.
just going to throw this out there, the OP is going for 17x8 +35, the pics in the thread you linked are 18x9 +35, and inch of width difference, therefore there is going to be about 12mm of inset versus the setup you linked right there. its not going to poke, if anything it might not be aggressive enough if he wants flush. especially once its dropped.
and to the OP if you want to have both front and rear equal, i would suggest 7mm spacers on the rear wheels.
FreshFRS is offline   Reply With Quote
Old 03-03-2014, 02:55 PM   #18
red_comet
Severed Member
red_comet's Avatar
Drives: Argento 2013 Scion FR-S Manual
http://www.ft86club.com/forums/showthread.php?t=7535
Go here, it tells you exactly what size/offset you need for flush fit at varying heights.
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN!
06 Xfire Bite me I liked it
13 FRS doriftoooo!
DON'T PANIC
red_comet is offline   Reply With Quote
Old 03-03-2014, 03:05 PM   #19
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
8.75" et33 isn't even flush in the rear 8" et48 is going to look very close to stock
Old 03-03-2014, 03:13 PM   #20
mad_sb
Drives: 2013 Asphalt FR-S
I was set on +35 until I saw how much poke that created in the front. Stock offset is bad, but poke is no better in my eyes. I opted for +45 and may add a 10mm spacer in the rear. Undecided until I get the new wheels on.
17x8 +35 does not poke, 17x9 +35 is about flush with the proper camber. Talking about front fitment.
Old 03-04-2014, 08:41 PM   #21
white86out
Awesome info everyone. Im gonna go 17x8 +35. I feel confident that it won't poke in the front.
Old 03-09-2014, 02:35 PM   #22
white86out
Okay, so I ordered 17x9 Rota Titans in flat black 42 offset. Had a good conversation with wheeldude, and they told me I would be much happier with 9in. The guy informed me that I wouldnt have any rub or alignment issues if I was only dropping the car on a prokit.
So Prokit and 17x9's it is! Should be here this week.
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 08:46 PM
Rotiform wheels on the track? dem00n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 07-20-2013 02:37 AM
plasti dip wheels and the track? subaruferrucci Tracking / Autocross / HPDE / Drifting 17 05-17-2013 01:36 AM
Best and cheap track wheels in 17x8 RYU Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 09-28-2012 01:10 AM
Anybody considered using 16" wheels for the track? ft86Fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 12-08-2011 09:55 AM
