Old 03-01-2014, 10:20 PM   #1
white86out
Getting new wheels, am I on the right track?
Alright, Im gonna order some Rota G-Forces. Here are the specs.
17x8 +48 offset.
Am I gonna need spacers to make these look decent? How big of a spacer will get me out to flush? Is +35 considered flush on both front and rear?
I just want to have all my ducks in a row before I push the button. Thanks for the help!
white86out is offline   Reply With Quote
Old 03-01-2014, 10:36 PM   #2
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Personally, I'd go for a lower offset.
hmong337 is offline   Reply With Quote
Old 03-01-2014, 10:55 PM   #3
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Yep, go for something with an offset closer to +35. No sense doing spacers when you can just get another wheel in the tight offset.
If you do have to go with spacers, go with the bolt-on type, in 15mm.
Slick is offline   Reply With Quote
Old 03-01-2014, 11:08 PM   #4
white86out
Gotcha, I just went back and looked at the wheels. I can get them in +38 or +35. I used the wheel fitment calculator on here, and it looks like +35 is pretty close to flush.
Opinions?
Old 03-01-2014, 11:43 PM   #5
hmong337
Emperor JDM
hmong337's Avatar
17x8 +38 is the perfect happy medium. I'd go with that.
Old 03-01-2014, 11:56 PM   #6
Steve
Steve's Avatar
Drives: 6MT
got 17x8 +35 going on in the spring myself, go for it
Steve is offline   Reply With Quote
The Following User Says Thank You to Steve For This Useful Post:
wparsons (03-02-2014)
Old 03-02-2014, 01:24 AM   #7
DAEMANO
Time Traveller
35 is better. Especially after the natural camber that comes from a drop.
Old 03-02-2014, 09:05 AM   #8
white86out
Yeah, I'm leaning towards 35.
The Following User Says Thank You to white86out For This Useful Post:
DAEMANO (03-02-2014)
Old 03-02-2014, 12:58 PM   #9
swilliams
swilliams's Avatar
Drives: 13 WRB BRZ
I was set on +35 until I saw how much poke that created in the front. Stock offset is bad, but poke is no better in my eyes. I opted for +45 and may add a 10mm spacer in the rear. Undecided until I get the new wheels on.
swilliams is offline   Reply With Quote
Old 03-02-2014, 02:35 PM   #10
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
I have the same 17x8 +45. I think they look great. Obviously not flush, but they don't look too sunk in either.
fender9530 is offline   Reply With Quote
Old 03-02-2014, 02:44 PM   #11
vtmike
vtmike's Avatar
Drives: Scion FR-S
I like my 17x8 +45. If you go with the 17x8 +35, I believe they poke out up front without a drop/camber.
Sent from my Nexus 7 using Tapatalk
vtmike is offline   Reply With Quote
Old 03-02-2014, 04:11 PM   #12
white86out
Hmmmm, now Im confused on which offset to go with
Old 03-02-2014, 05:18 PM   #13
swilliams
swilliams's Avatar
Drives: 13 WRB BRZ
Look at the pics in this thread. You can really see the poke on the black FRS. If you like the look of those cars, there's your answer.
Old 03-02-2014, 05:28 PM   #14
DAEMANO
Time Traveller
@white86out
The above is true for a car at stock height, however if you plan on lowering the car much at all, the minor "poke" of an et35 will camber in nicely to flush. If you pick higher offset (et45) and lower the car the tires will "suck" in due to the same natural camber. Keep this in mind.
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 08:46 PM
Rotiform wheels on the track? dem00n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 07-20-2013 02:37 AM
plasti dip wheels and the track? subaruferrucci Tracking / Autocross / HPDE / Drifting 17 05-17-2013 01:36 AM
Best and cheap track wheels in 17x8 RYU Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 09-28-2012 01:10 AM
Anybody considered using 16" wheels for the track? ft86Fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 12-08-2011 09:55 AM
