#15 |
Custom User Title
Drives: Asphalt FR-S MT
So are you planning on cutting into the car?
#16 |
BOXER FR
Drives: WRB BRZ Limited
i may have to but i think it`s considered "functional enough" if it lets any sort of heat out or just not have that ugly piece of black plastic that looks like a vent.
i would really rather not cut anything.
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
#17 | |
Drives: Silver Ignition Gundam
Also you should have an option to put a variety of trimmings over the bar (sort of like the chrome trimming to the BRZ) These trimmings can be anything suited to the buyer; chrome, carbon fiber, led, engraved lettering whatever. I'm just picturing it in my head. lol
#18 | |
Drives: 13 Whiteout 6MT
![]() You wouldn't have to remove the entire area behind the piece; you could simply use a hole-saw about 2-3" in diameter and then run some ducting into the bay and out to the fender. The negative pressure SHOULD pull air out of the bay at speed (although keep in mind that the front of the bay is pretty well sealed, so this effect would likely be minimal), and minimally while stationary. If you're just going for aesthetics, you could still use the same piece and just stick it on, of course. But I was thinking you'd use some sort of semi-open mesh to let the heat out if people were inclined to rig that up. FWIW, I've done this on previous vehicles (mostly 4x4/offroad designs) and have no qualms about taking a sawzall to my fenders/hood...wouldn't be the first time. Plus, the more you cut off, the more weight you save! I didn't have any issues with water coming in, even when using open-bottom hood vents on my Jeep. I'd imagine that a vertical mount, in combination with the use of a duct to get to the actual engine bay, would pose little issue to actual water entry. Just be mindful when washing.
#19 |
BOXER FR
more updates coming guys! ANY feedback is appreciated.
#20 |
BOXER FR
this is more or less what I am going for, except mine will be an added piece instead of being molded on the fender of course
#21 |
Drives: 2013 Scion FR-S White Out
I like... Subs
#22 |
Drives: 2012 Toyota 86
subbd
#23 |
BOXER FR
update of quick sketching today. please leave me feedback guys. thanks.
#24 |
Oh wow, that's a lot more cutting/ducting than I was envisioning. Have you mapped the path on the inner fenders? Having just spent some time there, they have a fair amount of conduit routed around there, so just need to make sure it's a clear shot.
Still, I'm liking it from the outside. Would have to see how tricky the install would be; compound angle cutting for those ducts may prove....tricky for the home DIY'er. Assuming the main exterior overlay is going to be body color, with some black/grey mesh? |
#25 | |
BOXER FR
#26 |
So what is actually functional about this? What is the intended purpose?
#27 |
BOXER FR
It would be for letting heat out from the engine bay. But the biggest reason for me is I just don't like the idea of a faux piece on my car.
#28 | |
it seems like this would just push air towards the firewall which wouldn't seem to do much. |
| Vent Side Marker | MaximaZero | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 02-23-2014 02:09 AM |
| BRZ Side Vent Trade | woode | NY / NJ / CT / PA | 4 | 12-31-2013 11:01 AM |
| Side vent change | Andrew_FRS_DD | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-12-2013 05:33 PM |
| frs side vent | lavisxice | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-02-2013 08:54 PM |
| Side Vent Swap? | Allankh | CANADA | 0 | 12-19-2012 02:26 PM |
