Old 02-28-2014, 12:19 AM   #15
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
So are you planning on cutting into the car?
Old 02-28-2014, 12:43 AM   #16
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
i may have to but i think it`s considered "functional enough" if it lets any sort of heat out or just not have that ugly piece of black plastic that looks like a vent.
i would really rather not cut anything.
mokinbird87 is offline   Reply With Quote
Old 02-28-2014, 02:31 AM   #17
IgnitionGundam
IgnitionGundam's Avatar
Drives: Silver Ignition Gundam
Originally Posted by mokinbird87 View Post
I am going to 3D print a silicon tube that sits flush with the vent on the inside and duct it into the engine bay.
I dont think it totally solves the issue though.. wonder how BMW M3s and M5s do it...
I dont know how "functional" these side vents can be without cutting into your fender/body. But I do like this look alot over the cheap plastic. Its simple and looks great. I think you should keep it cosmetic. Keep the metal vents. Back it up with some plastic from the inside (maybe covered in carbon fiber) to keep it sealed and prevent any water from seeping in. And finally flush the inside portion to the outside to make it only one piece. Now that would look sweet. I think.
Also you should have an option to put a variety of trimmings over the bar (sort of like the chrome trimming to the BRZ) These trimmings can be anything suited to the buyer; chrome, carbon fiber, led, engraved lettering whatever. I'm just picturing it in my head. lol
IgnitionGundam is offline   Reply With Quote
The Following User Says Thank You to IgnitionGundam For This Useful Post:
mokinbird87 (02-28-2014)
Old 02-28-2014, 09:32 AM   #18
FR-Slide
Drives: 13 Whiteout 6MT
How would you actually vent anything without cutting?
You wouldn't have to remove the entire area behind the piece; you could simply use a hole-saw about 2-3" in diameter and then run some ducting into the bay and out to the fender. The negative pressure SHOULD pull air out of the bay at speed (although keep in mind that the front of the bay is pretty well sealed, so this effect would likely be minimal), and minimally while stationary.
If you're just going for aesthetics, you could still use the same piece and just stick it on, of course. But I was thinking you'd use some sort of semi-open mesh to let the heat out if people were inclined to rig that up.
FWIW, I've done this on previous vehicles (mostly 4x4/offroad designs) and have no qualms about taking a sawzall to my fenders/hood...wouldn't be the first time. Plus, the more you cut off, the more weight you save! I didn't have any issues with water coming in, even when using open-bottom hood vents on my Jeep. I'd imagine that a vertical mount, in combination with the use of a duct to get to the actual engine bay, would pose little issue to actual water entry. Just be mindful when washing.
FR-Slide is offline   Reply With Quote
The Following User Says Thank You to FR-Slide For This Useful Post:
Old 03-10-2014, 12:17 AM   #19
mokinbird87
BOXER FR
more updates coming guys! ANY feedback is appreciated.
Old 03-10-2014, 12:24 AM   #20
mokinbird87
BOXER FR
this is more or less what I am going for, except mine will be an added piece instead of being molded on the fender of course
The Following 3 Users Say Thank You to mokinbird87 For This Useful Post:
Minovsky (05-04-2014), SkAsphalt (03-10-2014), suaveflooder (03-12-2014)
Old 03-10-2014, 01:28 AM   #21
White0utFrs
White0utFrs's Avatar
Drives: 2013 Scion FR-S White Out
I like... Subs
White0utFrs is offline   Reply With Quote
Old 03-10-2014, 04:36 AM   #22
troek
troek's Avatar
Drives: 2012 Toyota 86
subbd
troek is offline   Reply With Quote
Old 03-11-2014, 09:45 PM   #23
mokinbird87
BOXER FR
update of quick sketching today. please leave me feedback guys. thanks.
Old 03-11-2014, 09:51 PM   #24
FR-Slide
Oh wow, that's a lot more cutting/ducting than I was envisioning. Have you mapped the path on the inner fenders? Having just spent some time there, they have a fair amount of conduit routed around there, so just need to make sure it's a clear shot.
Still, I'm liking it from the outside. Would have to see how tricky the install would be; compound angle cutting for those ducts may prove....tricky for the home DIY'er.
Assuming the main exterior overlay is going to be body color, with some black/grey mesh?
Old 03-11-2014, 10:17 PM   #25
mokinbird87
BOXER FR
So yea... The ducting thing.. I'm gonna have to find the optimal size and the route. I'm imagining the main part to be body colored and then the rod part be either carbon fiber or aluminum.
The Following User Says Thank You to mokinbird87 For This Useful Post:
ZionsWrath (03-12-2014)
Old 03-11-2014, 10:59 PM   #26
z3ro
So what is actually functional about this? What is the intended purpose?
z3ro is offline   Reply With Quote
Old 03-11-2014, 11:05 PM   #27
mokinbird87
BOXER FR
It would be for letting heat out from the engine bay. But the biggest reason for me is I just don't like the idea of a faux piece on my car.
Old 03-11-2014, 11:22 PM   #28
z3ro
i'll accept the 2nd part as a good answer but the first i'm still skeptical.
it seems like this would just push air towards the firewall which wouldn't seem to do much.
Vent Side Marker MaximaZero Cosmetic Modification (Interior/Exterior/Lighting) 28 02-23-2014 03:09 AM
BRZ Side Vent Trade woode NY / NJ / CT / PA 4 12-31-2013 12:01 PM
Side vent change Andrew_FRS_DD Cosmetic Modification (Interior/Exterior/Lighting) 1 07-12-2013 06:33 PM
frs side vent lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-02-2013 09:54 PM
Side Vent Swap? Allankh CANADA 0 12-19-2012 03:26 PM
