Old 02-24-2014, 12:18 PM   #15
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Don't ride the clutch.
You should pass through the transition point as fast as you can while launching smoothly. Typically this is where throttle is applied.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 02-24-2014, 12:27 PM   #16
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Make sure you have the latest ECU update on your car with the Idle monitor fix, I think I kind of know what your talking about with the unstable idle. Keep in mind the ECU is always learning so things can change depending on how you drive the car.
For the BRZ the new ECU update came out here a few weeks ago.
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 02-24-2014, 12:27 PM   #17
humfrz
Originally Posted by goshem View Post
Do I really have to do that? I mean I can feel the clutch grab real hard still, it's just that I thought it isn't normal how it's not really rolling smoothly on the engagement point in 1st gear and the rpms bouncing after I put the clutch in completely.
Oh, my .....
goshem, I'm thinken you may be "grabbing" for things to worry about.
As shown by @Porsche up above, that test will help determine if your clutch disk is about wore out or your pressure plate is weak or the clutch is way out of adjustment.
If your clutch is "chattering" it will be quite apparent (it sounds like a thrashing machine).
If it is out of adjustment (one way) you won't be able to put your car in gear if the engine is running.
So, it sounds to me like your clutch is "normal". If in doubt, I suggest you go down to the dealership or to a meet up and drive another MT car ....
humfrz
Old 02-24-2014, 02:06 PM   #18
stugray
Drives: 2013 GBS BRZ Limited
Would you please post the ROM ID of this new ECU update you speak of?
And is that for a 2013?
Old 02-24-2014, 02:38 PM   #19
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by SloS14 View Post
Are you like using the clutch pedal and not using the accelerator at all? If so...there is no reason to ever do that.
Required when doing extremely slow and careful maneuvers in and out of a very tight garage. Otherwise with normal driving, no need even with traffic creep.
krayzie is offline   Reply With Quote
Old 02-24-2014, 03:39 PM   #20
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
"Required" must have a different meaning in Canada eh?
SloS14 is offline   Reply With Quote
Old 02-24-2014, 04:10 PM   #21
goshem
goshem's Avatar
Drives: 16' WRX
Originally Posted by Porsche View Post
Find a level open space where you can check your clutch without any danger of running into anything.
Park your car with the engine running.
Firmly apply the handbrake.
De-clutch. Engage 5th gear.
Very s-l-o-w-l-y engage the clutch.
Can you engage the clutch fully without the engine stalling?
If so, your clutch is badly worn and requires replacement.
If the engine stalls immediately, then your clutch still has sufficient bite. Who knows for how long?
You may have a bit of oil, or something, on your clutch disc, or the disc may be glazed.
Try "burning it off" by doing a couple of aggressive launches, a.k.a. drag racing starts.
Good luck.
Ok so I just tried doing what you said. I let it half way and it certainly catches but if I completely let out the clutch I'm almost 100% sure it will stall out. So what's the deal?
goshem is offline   Reply With Quote
The Following User Says Thank You to goshem For This Useful Post:
Porsche (02-24-2014)
Old 02-24-2014, 04:15 PM   #22
humfrz
Well, it could be "required".
Say you had just left your lover's apartment and you were down in the parking garage, with a car with loud exhausts, and as you were just about to leave, you noticed her husband (which you knew) walking through the garage .....
humfrz
Evil Jesus (02-24-2014)
Old 02-24-2014, 04:20 PM   #23
Mikem53
Drives: FR-S 6MT
I'm 700 miles in, and when I hold the clutch at the engagement point at a flat area it BARELY moves like <1mph and the rpms drops and goes up repeatedly (fluctuates). I feel that when I fiest got the car it would go a little bit faster and the rpms didnt use to do that when I first took delivery.
Is there something wrong with the car?
Is your complaint about the clutch slipping or the rpms fluxuating under a load?
Older 13's have a TSB out for idle issues..
I'm used to v8 where u let the cluch out slowly without any accel and then u use the gas to go.. This car however will tend to bog and stall using the same technique.. I still try for the grab at low rpms.. but u have to be already on the gas early, before complete engagement.. You really have to drive this car to get it smooth.. Gets more natural with time..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Old 02-24-2014, 04:24 PM   #24
goshem
goshem's Avatar
Drives: 16' WRX
Idk now I'm scared I just did the clutch test in 5th gear and it didn't immediately stall out.. (
Old 02-24-2014, 04:26 PM   #25
Mikem53
Drives: FR-S 6MT
Sounds like your clutch is shot..
Old 02-24-2014, 04:29 PM   #26
goshem
goshem's Avatar
Drives: 16' WRX
I can't believe it, I just got the car and never dumped the clutch nor rode the clutch too hard (over 2k rpms) or rode the clutch too long.. How can this happen?
Old 02-24-2014, 04:38 PM   #27
n2oinferno
Praise Helix!
n2oinferno's Avatar
New to driving stick? Ever smell a burning, nasty smell while you're driving? Kinda like tires, but maybe worse? Slipping the clutch too much, too often will wear it out. Sucks, but it's a learning thing. I toasted a clutch while I was learning to drive too, not the end of the world. Pockets hurt for a bit though.
The Following 2 Users Say Thank You to n2oinferno For This Useful Post:
goshem (02-24-2014), Porsche (02-24-2014)
Old 02-24-2014, 04:50 PM   #28
chas3wba0
chas3wba0's Avatar
Drives: Yes
I kind of get what your saying. Doesn't happen all the time, but sometimes the idling RPM's will drop so that I will stall when trying to launch normally like I always do, leading me to think I'm still a sh0ddy MT driver after 4000 miles. It's a known issue with this car though, just feather the throttle more
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Anyone elses panel filter not fit properly? Darryljr11 Engine, Exhaust, Transmission 15 03-14-2013 11:12 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
