Old 02-17-2014, 09:17 PM   #15
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Ironsquid View Post
im done with it, too small
The Following User Says Thank You to cdrazic93 For This Useful Post:
Ironsquid (02-17-2014)
Old 02-17-2014, 09:20 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by jamesm View Post
That's what I'm thinking, but id hate to have to upgrade again .
Are you really wanting to use the extra overhead the 3582 offers...thats rated for 650 hp right? built block right there, tranny swap, rear axle and diff...thats a good 20k in parts, then add labor, if you wanted to use the 3582 for its full potential. unless you have future track only plans for it, I wouldnt, but thats just me! By no means am i as knowledgeable about what will suffice for a DD at 550+ whp.
Old 02-17-2014, 09:21 PM   #17
jamesm
james you can have my 35r im done with it, too small, going 42101 twin scroll
I'll hold you to that .
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Ironsquid (02-17-2014), Sportsguy83 (02-17-2014)
Old 02-17-2014, 09:22 PM   #18
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
The low boost and lag is horrible.
/sarcasm
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 2 Users Say Thank You to woode For This Useful Post:
Old 02-17-2014, 09:23 PM   #19
lexusb3
Drives: FRS
U made me spend money -_- since that video
lexusb3 is offline   Reply With Quote
Old 02-17-2014, 09:23 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Cancel that 3076, becausefreeturbo
jamesm (02-17-2014)
Old 02-17-2014, 09:27 PM   #21
stevo585
Drives: White 2014 BRZ
I hope this is a troll post.
What sounds very cocky? Why even say that? Just because you need the biggest turbo possible doesn't mean I do. I came from a TD04 WRX that had a "mountain" of torque. Full spool before 2.5-3k is what I'm looking for.
Although hard to believe from a 2.0L, from the posts it appears this motor spools "big" turbos pretty quickly. Enough said. End of story. No need for a small turbo.
Thanks for the responses.
stevo585 is offline   Reply With Quote
Old 02-17-2014, 09:31 PM   #22
mrk1
Drives: Sterling BRZ Ltd
I love the td04, sure its not going to break any record buts its fun. I have a really tired one on the back shelf at my shop and I'll admit I held it in the engine bay when I made my manifold. Those little guys with a big down pipe sound great.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-17-2014, 09:34 PM   #23
stevo585
the reason is because this car is very knock limited on pump gas, and a lot of people don't have or want e85. bigger turbos flow more air for a given boost pressure. so you make more power on less boost, all while moving cooler air which in turns helps to raise the knock threshold. combined with direct injection and 12.5:1 compression, lag is hardly an issue (the 35r i just tuned, with very little optimization, spools 14psi @ 4.5k rpm for instance). these cars can spool a much larger turbo much quicker than what you'd expect if you come from the evo/wrx world.
beyond that, you have the overhead to produce craaaaaazy power on e85 should you choose to. larger turbos are also easier on drivetrain parts, as they tend to ramp in the torque curve more progressively than a smaller turbo. lots of immediate torque at low rpm does little more than turn tires into vapor and break stuff.
so there are lots of reasons, and having bought a 'small' turbo (gtx2867r) and tuned larger ones, i'll be swapping mine out for something much larger very soon. the benefits far outweigh any perceived drawback, most of which are just a consequence of applying common knowledge that doesn't apply to the fa20. this engine breaks rules.
Thanks. A very informative post. What I was asking for.
Old 02-17-2014, 09:44 PM   #24
stevo585
Same here. Felt like V8 power instant torque. No sense of lag at all really on the 2.5L. Not looking to break records, just looking to make some nice usable power without having to upgrade the fuel system, drive train, etc.
Honestly I like to drive not work on broken cars or drop my 401k into it
Old 02-17-2014, 09:53 PM   #25
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
You mention cocky, Ill refer you to your original post. Something about enjoying lag something something.
I know who you are btw, we met a couple weeks ago and your "comments" during our Orlando 86 meet werent very thought out.
I will give you a thought. If you manage to make 300 whp with full spool at 2500 rpm let me know what size and brand tires you plan on hooking with.
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
DriftEightSix (02-18-2014)
Old 02-17-2014, 09:54 PM   #26
jamesm
Just because a turbo is good for 650whp doesn't mean it isn't great for less than that.
The Following 4 Users Say Thank You to jamesm For This Useful Post:
Kris86 (08-30-2016), SirBrass (02-17-2014), stevo585 (02-17-2014), TRD_07 (02-18-2014)
Old 02-17-2014, 10:28 PM   #27
stevo585
Ah right your car is the same color as a ZX6r I remember. Cool color. Anyways well share the knowledge? I'm just trying to learn about an FA20 on boost. It apparently doesn't have the lag issues of other subaru (EJ) motors. I get it now.
I'd imagine you need RS3's in 245+ or the like to hook up but would you not have the same issues @ 400-500 whp no matter what tire you use? Ever see a corvette tires yeah they are massive for a reason. My Dad has one and they still can spin.
Old 02-17-2014, 10:33 PM   #28
SnapOv3st3r
Drives: 400whp Scion tC
PTuning system comes with a GT3076.
/thread
SnapOv3st3r is offline   Reply With Quote
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
!!!Limited time only sale on Greddy Turbo Kits with Free Boost Gauge!!! vividracing Forced Induction 0 01-24-2014 01:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Turbo Kits: Rational boost threshold yet? Ryephile Forced Induction 88 01-22-2013 12:05 AM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 02:53 PM
