Old 02-19-2014, 09:01 PM   #15
oaroyale
Drives: Black BRZ
all the research i've done so far said the rear camber bolts are a pain in the ass to install. i've got quotes from shops that said it would take around three hours to install. so you are looking at $300 to $400 with parts and labor. the SPC LCA can be have for around $200 and the installation is much much easier than the bushing, so you can either do it yourself or pay a small fee for a shop to do it. You can of course buy other LCA that costs upwards of $450, but for what i need the SPC LCA will do.
Originally Posted by DrDuquette View Post
Whoops. I thought "Bang for the Buck" was talking about camber bolts verse LCA for the rear. I'm SO confused!
So I bought the camber bolts for the upper control arm of the REAR. They are on there way. But should I change my tune and go for LCA's if I am planning on 1-1.5" drop for a DD car? What's your thoughts. I'll save $300-400 with the bolts verse the LCAs.
oaroyale is offline   Reply With Quote
The Following User Says Thank You to oaroyale For This Useful Post:
DrDuquette (02-19-2014)
Old 02-19-2014, 09:28 PM   #16
Malt
Drives: 2015 WRX
Not sure what shop quoted you 3 hours, but don't be surprised when it takes them twice as long.
Malt is offline   Reply With Quote
Old 02-19-2014, 09:29 PM   #17
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I'm planing on doing them myself. Looks straight forward.
DrDuquette is offline   Reply With Quote
Old 02-20-2014, 09:00 AM   #18
Malt
Drives: 2015 WRX
Best of luck. I've installed all the mods on my car and once I saw that the bushings had to be hammered out and how much of the rear needed to come apart to get the upper arms out I decided it was more trouble than it was worth.
EDIT: if you were talking about LCA instead of the upper bushings than ignore the above
The Following User Says Thank You to Malt For This Useful Post:
DrDuquette (02-20-2014)
Old 02-20-2014, 09:17 AM   #19
Assunta
Assunta's Avatar
Drives: 2013 SWP BRZ
AFAIK, putting camber bolts in the rear upper control arm allows you to pull the top of the wheel in for rear camber adjustment. The LCA controls camber by adjusting the bottom of the wheel.
See http://www.whiteline.com.au/product_..._number=kca326
And also these useful pics courtesy of CarWatch Japan.
I know this hasn't answered your question directly, but look at the differences in labour between the two parts. Personally, I prefer LCA.
Assunta is offline   Reply With Quote
Camber Bolts in Rear DIE1000DEATHS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 05-13-2015 10:19 AM
Eibach sportline, SPC rear LCAs, Whiteline front camber bolts Shad0ez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-17-2013 11:52 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Most bang for the buck? GIMMICK Scion FR-S / Toyota 86 GT86 General Forum 24 05-07-2013 07:10 PM
