Old 01-30-2014, 04:35 PM   #15
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Originally Posted by knipple View Post
The FR-S is in STX, it isn't legal for STU as it isn't listed in STU. If a car isn't specifically listed in a Street, Street Touring, or Street Prepared classes, it isn't legal for that class.
Thanks for the clear up
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 01-30-2014, 04:39 PM   #16
knipple
Drives: 2013 Ultramarine Scion FR-S
No Problem, Did you notice my previous post where I indicated the two Items you have installed that bump you out of STX? By the way, this was from reading the rule book which isn't an easy read and can be confusing if you are not used to looking in it to determine the class of a vehicle.
knipple is offline   Reply With Quote
The Following User Says Thank You to knipple For This Useful Post:
sosick (01-30-2014)
Old 01-30-2014, 04:42 PM   #17
sosick
fastest frs in sbg
sosick's Avatar
No. I will look for it tho. Ive been up and down this autox forum looking for info on my Frs. which parts btw?
2014 firestorm frs
Old 01-30-2014, 04:44 PM   #18
sosick
fastest frs in sbg
sosick's Avatar
Not sure which two but im able to remove any of the parts
2014 firestorm frs
Old 01-30-2014, 04:44 PM   #19
knipple
Perrin Master Cylinder Brace (CSP)
Megan Differential Support Bar (SM)
BTW, How wide are your wheels?
sosick (01-30-2014)
Old 01-30-2014, 04:45 PM   #20
sosick
fastest frs in sbg
sosick's Avatar
Lol found it so remove the diff brace and brake brace. Would i be able to put inserts in the diff or no?
2014 firestorm frs
Old 01-30-2014, 04:46 PM   #21
sosick
fastest frs in sbg
sosick's Avatar
18x8 f 18x9 rear. I think 17x8 f 17x9 rear might be a better setup right? Is there any restrictions on on offset?
2014 firestorm frs
Old 01-30-2014, 04:47 PM   #22
knipple
What do you mean by inserts?
sosick (01-30-2014)
Old 01-30-2014, 04:49 PM   #23
sosick
fastest frs in sbg
sosick's Avatar
http://www.rawbrokerage.com/powerfle...nsert-frs-brz/
2014 firestorm frs
Old 01-30-2014, 04:50 PM   #24
knipple
Do you have a picture of the Megan Racing Differential Support you have installed? The picture I found of it showed as a support bar. If they are just the bushings, they are legal for STX. How wide are your wheels?
sosick (01-30-2014)
Old 01-30-2014, 04:50 PM   #25
knipple
Those are legal for STX.
sosick (01-30-2014)
Old 01-30-2014, 05:09 PM   #26
knipple
I should have mentioned this earlier, but as a novice, don't worry so much about class. Also, don't worry about how other drivers are doing. Concentrate more on having fun and improving times. When you have some seat time, and a better clue as to where you want to be with your car, then worry about the class you are in.
sosick (01-30-2014)
Old 01-30-2014, 05:14 PM   #27
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Perrin
That'll kick you out of the STX class and into Street Prepared (where we aren't competitive at all). I have the same one and will have to remove it if I do STX. I think the master cylinder brace is also illegal in STX - someone correct me if I'm wrong!
PoorMansRacing is offline   Reply With Quote
The Following User Says Thank You to PoorMansRacing For This Useful Post:
sosick (01-30-2014)
Old 01-30-2014, 05:17 PM   #28
PoorMansRacing
Anorexic
I agree with @knipple. In your novice season, you can run, depending on your region, as a Novice. Sometimes they'll class it (e.g. N-STX), but not always. Local clubs won't care about your mods as much. You can always run as non-compete and have a blast. If autox is for you, then start planning for a class later.
The Following 2 Users Say Thank You to PoorMansRacing For This Useful Post:
sosick (01-30-2014), ultra (02-01-2014)
noob help juanam0909 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-28-2013 02:17 PM
Im a noob at this... CSI:86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-30-2013 01:20 PM
Noob to this. Style Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 09:10 PM
Noob how often do you check you oil Fugazi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 07-06-2012 06:58 PM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 07:31 PM
