Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 01-14-2014, 05:04 PM   #15
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
The area we're talking about is in the picture below....
PhastekSport is offline   Reply With Quote
Old 01-14-2014, 05:15 PM   #16
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Ahhh I was thinking it was the blank spot like the OEM kit...that button fits in that spot? It looks taller then the hole there....have any pics installed? Very tempting even though the surrounds are gloss nothing some paint wouldnt fix.
Fett4Real is offline   Reply With Quote
Old 01-14-2014, 05:38 PM   #17
weedtank
weedtank's Avatar
Drives: Ultramarine
can you confirm where the switch goes with an installed pic? it looks like it is made for the trunk release space
weedtank is offline   Reply With Quote
The Following User Says Thank You to weedtank For This Useful Post:
Fett4Real (01-14-2014)
Old 01-14-2014, 07:02 PM   #18
PhastekSport
Here we go. Took about 3 minutes to get it in.
Quick install video for the switch:
[ame]http://youtu.be/JykXGNfsVi8[/ame]
The Following 4 Users Say Thank You to PhastekSport For This Useful Post:
Fett4Real (01-16-2014), vincent201089 (01-14-2014), weedtank (01-14-2014), xdudefromheaven (01-17-2014)
Old 01-14-2014, 10:00 PM   #19
vincent201089
vincent201089's Avatar
Drives: frs
1 more question. With this kit, could I turn the fog light on whenerver I want? I mean Can I turn it on when my headlight is off or I only can turn it on/off when headlight is on?
Btw, very nice kit, good price and clean.
vincent201089 is offline   Reply With Quote
Old 01-14-2014, 11:31 PM   #20
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Originally Posted by Chris@Phastek View Post
I understood :-). I just wasn't sure if the premium stalk had something there despite the fact (figured it wouldn't, but I've seen crazier stuff).
The area that it fills is:
Don't you have the HID leveling switch here?
The fog lamps would fit though.
Thanks for clarifying, to bad these won't fit
Ny Brz is offline   Reply With Quote
Old 01-14-2014, 11:56 PM   #21
sirsol66
Drives: 2013 FRS- Hot Lava
Is there a DIY for this? Very interested.
sirsol66 is offline   Reply With Quote
Old 01-16-2014, 12:23 PM   #22
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Just ordered i hope i get them soon
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 01-16-2014, 12:56 PM   #23
PhastekSport
Hopefully the overview video and switch install can get you through it. The bezels in the front just pop in and out. Start with one corner and work your way around.
To run a wire through the firewall grommet this is what I would do. Tape the yellow wire to a metal coat hanger that you've straightened out. Force it through the grommet and grab the other end from inside the vehicle.
My personal vehicle already has fog lights installed so we won't be tearing it down unfortunately.
They should ship out today from Houston, TX. Thanks!
Old 01-16-2014, 01:38 PM   #24
sirsol66
One main question: That 12 volt ignition tap necessary on the actual switch, is that only to power the actual switch?
I would rather not tap into any actual wiring on the car (such as the switched power), so I'm hoping just hooking up the positive/negative to the battery and plugging in the switch would allow for it to function, WITHOUT running that second power and ground. Could you please confirm? Thank you
Old 01-16-2014, 01:51 PM   #25
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
You SHOULD be able to find a spot on the fuse box that is ACC and plug into it...thats what Ive done in the past on fog kits
Old 01-16-2014, 03:37 PM   #26
PhastekSport
It will not function without that wire being supplied 12V. Basically the switch will not complete the circuit even if it is in the on position without a signal from the red (ignition) wire. This is to allow an installation in which the fog lights turn off as soon as the key is out of the ignition.
I borrowed this image from a thread that borrowed it from another thread. Someone on here earns credit.
The DRL circuit should only be hot with ignition power. Using an "add a fuse" is recommended if you want a configuration which can be returned to stock in the future.
Old 01-16-2014, 03:47 PM   #27
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
The slashed ones blank no power? Normally they put in extras for additional stuff...Ima take a look with a tester later, either way...any kinda deal for headlight/foglight bundle?
Old 01-16-2014, 03:57 PM   #28
PhastekSport
The slashed out ones aren't in use, but usually have constant power prongs. Probably wouldn't want to use that.
Just message me your shipping information and exactly what you were interested in (chrome / black). I'll give you a quote.
The Following User Says Thank You to PhastekSport For This Useful Post:
fog light, fog light kit, frs
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 09:14 PM
**PHASTEK** Winjet JDM Replica Headlight and Tail Light Thread PhastekSport Exterior Parts - Lighting 62 04-22-2015 05:15 AM
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 10:39 PM
*Phastek* Winjet Coverage @ SEMA 2013 - JDM Replica Headlights, Fogs, Tails PhastekSport Cosmetic Modification (Interior/Exterior/Lighting) 82 03-09-2014 01:32 AM
Winjet JDM Style Headlights Groupbuy --> Round 2 Now Open!! 86_ZN6 Groupbuys 206 02-13-2014 06:45 PM
