Old 01-07-2014, 06:37 PM   #15
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
I use 3 usually, it's pretty well lit around where I drive.
oldpueblo is offline   Reply With Quote
Old 01-07-2014, 07:03 PM   #16
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Kuri View Post
I run mine in zero :|
ditto. I feel like they cut off to sharply. it goes super bright to a line of drakness.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 01-07-2014, 08:29 PM   #17
husker741
Originally Posted by Chee-Hu View Post
I have not had anyone flash me for 14 months.
You usually gotta pay double for that kind of action, Cotton.
husker741 is offline   Reply With Quote
The Following 2 Users Say Thank You to husker741 For This Useful Post:
Anthonytpt (01-08-2014), sklimo (01-08-2014)
Old 01-08-2014, 11:19 AM   #18
Chee-Hu
Chee-Hu's Avatar
I don't usually spend time and $ in those kind of places.
Chee-Hu is offline   Reply With Quote
Old 01-08-2014, 12:58 PM   #19
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
i've gone through 3 light setups with my FR-S, and nobody has ever flashed me in 17 months of ownership. Stock -> PnP HID kit -> 10-series
Old 01-08-2014, 01:22 PM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Sniper2606 View Post
Its been almost a year with my 2013 Brz now love the car
Im not sure if people are just sensitive to bright HIDs now or just pissed, ever since i bought the car i been flash with high beams more than i can remember i flash back to let them know im not using my high beams.
Anybody else with this problem?
I've never been flashed in the BRZ at the highest setting. I've seen other BRZs running at lower settings that were as high or higher than mine. :shrug:
I get flashed in the M3 a bit, it has FXR projectors (a proper retrofit - not a PnP crap setup). That's due to the crap suspension on the car bouncing though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-08-2014, 01:29 PM   #21
OrbitalEllipses
Drives: Attitude
I've been flashed a few times - I get some schadenfreude satisfaction in flashing them right back with my even brighter brights.
KelvinBRZ (01-10-2014)
Old 01-08-2014, 02:37 PM   #22
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
as a retrofit'd owner, I agree with you. When someone flashes me, I can blind them back
Old 01-09-2014, 02:05 AM   #23
Poodles
Drives: 2015 Series.Blue
The level adjustment is only for when you have weight in the back... if you're lowering the lights, you're hurting your range (this is important as you you'll outrun your headlights at a lower speed than normal)
Are you hauling stuff around in your trunk or back seat?
Old 01-10-2014, 05:57 PM   #24
xcelir8brz
Easy fix. Roll the dial to 4. Open hood and manually adjust height of each headlight against a garage or something until you like it. Drive car. Now you can go high or low with dial. You now have so much control that how it was set from factory.
Sent from my SCH-I545 using Tapatalk
xcelir8brz is offline   Reply With Quote
Old 01-10-2014, 06:21 PM   #25
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
The proper way to adjust the height of projector beams is to use an alignment machine, not against the wall that's just ghetto lol!
krayzie is offline   Reply With Quote
Old 01-10-2014, 06:48 PM   #26
wheelhaus
wheelhaus's Avatar
I usually adjust the level control so I can see the cutoff below other drivers side mirrors. This is usually a 1 or 0 depending if there's junk in the trunk or not. Even with the slab style road construction around southern Denver (lots of bouncing back and forth) causing the cutoff to bounce into their mirrors and oncoming cars, I haven't been flashed in all 18 months of owning the car.
wheelhaus is offline   Reply With Quote
Old 01-10-2014, 08:00 PM   #27
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Mine is always 0. I switch back between 0-1 though however. I just feel more safe with my HIDs covering a further field of vision :/
GBS Mafia
KelvinBRZ is offline   Reply With Quote
The Following User Says Thank You to KelvinBRZ For This Useful Post:
Kuri (01-13-2014)
Stock FR-S Headlights & Tail Lights, Morimoto Elite HIDs, and OEM Mud Guards tbox Exterior Parts (Aero, Lighting, Etc.) 14 01-11-2014 02:18 PM
My car got broken into. Thieves not too bright... hansthegerman Scion FR-S / Toyota 86 GT86 General Forum 17 10-26-2013 05:41 PM
Are Your LED's Bright Enough?? Check This Out! 86_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2013 06:31 PM
Bright White Turn Signals for SALE ! ScionFR-S Exterior Parts (Aero, Lighting, Etc.) 4 06-21-2013 12:12 PM
Super bright headlight modifications AtlasMick Cosmetic Modification (Interior/Exterior/Lighting) 9 04-17-2013 03:17 PM
