Old 01-08-2014, 11:39 AM   #15
andrew20195
Drives: 2013 Subaru BRZ
Subaru has a TSB on this issue. 12-152-13 is the bulletin number. Fix is installing new mounting bolts with thread locker.
andrew20195 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew20195 For This Useful Post:
bestwheelbase (01-08-2014), civicdrivr (01-10-2014)
Old 01-08-2014, 11:46 AM   #16
ZionsWrath
Thanks
ZionsWrath's Avatar
When do you notice this lol...
Does it like vibrate in the wind or something? I has a first shipment BRZ and haven't notice anything with the mirrors and I have had it at some decent speed.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Anthonytpt (01-08-2014)
Old 01-08-2014, 12:25 PM   #17
xxscaxx
Drives: 2013 SWP BRZ
I had this on my passenger side mirror. Its easy to fix. You need to just take off the mirror (pop the black plastic off, remove the 2 10mm bolts), and tighten the bottom screw on the mirror housing. I fixed this when I installed my heated convex mirrors with turn signals.
xxscaxx is offline   Reply With Quote
The Following 2 Users Say Thank You to xxscaxx For This Useful Post:
Gords_zenith (01-10-2014), humfrz (01-08-2014)
Old 01-08-2014, 12:58 PM   #18
choi0706
Drives: t
it flops in the wind.. really aggravating, when your on the freeway checking your mirrors and they're moving away from your blind spot.. they flop depending on the car infront.. also moving from a stand still..
choi0706 is offline   Reply With Quote
Old 01-08-2014, 01:42 PM   #19
Jlin
Drives: FRS
Thats exactly my issue for the passenger side but my drive side mirror itself is loose.
Sent from my SGH-I747M using Tapatalk 4
Jlin is offline   Reply With Quote
Old 01-08-2014, 01:45 PM   #20
choi0706
Drives: t
[ame]http://youtu.be/KqAC_isIwyM[/ame]
Old 01-08-2014, 02:19 PM   #21
jonbonazza
Mine are tight... tight like a tiger.
jonbonazza is offline   Reply With Quote
Old 01-10-2014, 03:31 AM   #22
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Does anyone know if there's a toyota tsb for this?
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 01-22-2014, 04:38 PM   #23
choi0706
Drives: t
fixed it.. tighten the phillips head screws inside the mirror base..
The Following User Says Thank You to choi0706 For This Useful Post:
humfrz (01-22-2014)
Old 01-22-2014, 04:38 PM   #24
choi0706
Drives: t
can be done in under 3min..
heated mirrors? gxgn DIY (Do-It-Yourself) Guides 141 11-15-2016 08:27 AM
WTT: My cf mirrors for your Raven mirrors- PLEASE LOCK FR-Shadow Exterior Parts (Aero, Lighting, Etc.) 3 09-25-2013 10:01 AM
heated mirrors mwlhrh Scion FR-S / Toyota 86 GT86 General Forum 9 08-06-2013 01:55 PM
Options for mirrors diss7 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-20-2013 08:26 AM
Use of mirrors whaap Scion FR-S / Toyota 86 GT86 General Forum 26 10-25-2012 11:14 PM
