Old 10-25-2012, 11:41 AM   #1
whaap
whaap's Avatar
Use of mirrors
A new member just announced getting his new car and also mentioned how he didn't like the blind spot on the drivers side of the car. That prompted me to do a little write up about what is perhaps the biggest mistake made by automobile drivers.
If, when you're driving, you can see the car behind you in all three of your mirrors, you owe it to yourself to continue reading this even though it will seem a little lengthy.
Your mirrors should be set up in such a manner that you are looking at a panoramic view, not three views of almost the same thing. As suggested above, if you see that car behind you in all three mirrors you're not benefiting from your side view mirrors.
It will take some time to get this right but if the car that has been behind you starts to pass you on the left side of your car, your left side mirror should be out far enough that he starts to come into view in your left side mirror before he is totally out of view in your rear mirror. Likewise he should be in your peripheral view before he goes out of view in your left mirror. At the very least it would require a small head check to your left.
The same applies to cars that are passing you on the right side. Get that mirror out there so that he only comes into view in the right side mirror just as he's going out of view in the rear mirror. Again, you should be able to easily see him without any mirrors when he leaves the view of your right side mirror.
It will take some getting used to and it will also take some fine tune adjustments to get things right. However, if you get on a multiple lane road where you can position yourself so that cars pass you on both sides it's not difficult to make the adjustments properly.
With a little practice you'll discover you don't need to add those stick on, convex dot-mirrors.
whaap is offline   Reply With Quote
Old 10-25-2012, 11:50 AM   #2
Spd229
Spd229's Avatar
Drives: Ultramarine FR-S AT
This has been mentioned in a few places as well as a link with a car and driver explanation.
Thanks for putting this in its own topic though, I'm sure it'll do some good (not using thread nazi sarcasm) . Perhaps add the car and driver link at some point as it has a few diagrams.
Spd229 is offline   Reply With Quote
Old 10-25-2012, 12:19 PM   #3
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
FYI
Figures 1, 3, and 4 are how your mirrors should be adjusted.
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
Old 10-25-2012, 01:06 PM   #4
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I've been using this ever since I read that car and driver article. All my friends think I'm crazy for doing it this way but it makes life so much easier on the highway since I don't even have to turn my head.
Tt3Sheppard is offline   Reply With Quote
Old 10-25-2012, 01:11 PM   #5
CBR600RR
Drives: Raven Black
Thank you OP - Most drivers out there dont know this!
Old 10-25-2012, 01:16 PM   #6
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Where I'm from there's no such things as 4 lanes roads so everybody has their mirror set to see their own car - who needs to see the car going away in the other lanes or the sidewalk?
It makes total sense to set them up in a city environment however. I've been driving like that for a few years, no more looking over the shoulder.
Rayme is offline   Reply With Quote
Old 10-25-2012, 01:16 PM   #7
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
that's very useful thanks, and to think for all these years i've been setting my side mirrors so that they always show the side of my car...
Vladror is offline   Reply With Quote
Old 10-25-2012, 01:19 PM   #8
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
if your driving fast enough, you dont need mirrors....
i kid..i kid.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 10-25-2012, 01:45 PM   #9
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
See, this is probably one of my biggest concerns for when I get my FR-S. My current car is very easy to see out of, being a sedan, all four windows offer a very clear view of the road, so I rarely check my mirrors to look at my blindspots, instead I prefer to turn and look, and I always see everything that way. I've never been very good at using the mirrors for anything, sad to say. I'm not sure why, but it might be the flipped orientation. I prefer seeing things from my point of view, instead of reversed in a mirror.
That being said, it looks like the FR-S is going to force me to use this tactic if I want to be a safe driver. Guess the first thing I'll do when I sit in it is change the mirror positions.
Nevermore is offline   Reply With Quote
Old 10-25-2012, 02:24 PM   #10
wbradley
Sarcastic SOB
wbradley's Avatar
OP-
Thank you for bringing this up. For some of the less experienced drivers or those who weren't aware of this, you definitely will be safer if you set your mirrors right.
Here is my method, tried and true:
Just make sure your left and right mirrors are set wide enough that you can't quite see the side of your car in that mirror. I have found most people see all the way down the side of their car, which is useless. If you widen the view to *just* past seeing the side of your vehicle you will have an optimal panoramic view and absolutely minimize any blind spots.
Old 10-25-2012, 02:52 PM   #11
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
This car is no harder to see out of than any other car I've owned, in fact its much easier.
Was everyone else driving a top down miata before!?
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 10-25-2012, 02:59 PM   #12
lazyluka
Drives: GT86
I still use the old method where your car is just barely visible in the mirror.
I tend to pay so much attention when I am driving I can tell you whatever car's are around me. I will know a car is in my blind spot without having to turn my head because I already saw him a few seconds ago moving into my blind spot.
However, this does seem like it would help so will try it out when I get the 86.
lazyluka is offline   Reply With Quote
Old 10-25-2012, 03:11 PM   #13
Tt3Sheppard
Just need to move the right mirror when wanting to park on the street. Don't want to curb those rims!
Old 10-25-2012, 03:18 PM   #14
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I would note - as much as arranging your mirrors this way helps, I would suggest that we don't do away with the quick shoulder check.
daiheadjai is offline   Reply With Quote
heated mirrors? gxgn DIY (Do-It-Yourself) Guides 141 11-15-2016 08:27 AM
Power folding mirrors trinitron Cosmetic Modification (Interior/Exterior/Lighting) 60 08-17-2016 12:00 AM
anyone else love APR GT3 Mirrors ???? ESBjiujitsu Cosmetic Modification (Interior/Exterior/Lighting) 23 04-10-2016 12:13 PM
FS: FRS (oem) Side Mirrors (pair) NRG x FRS Exterior Parts (Aero, Lighting, Etc.) 4 05-06-2013 12:34 AM
Fr-s Power Folding Mirrors? Koolkiid Cosmetic Modification (Interior/Exterior/Lighting) 19 09-15-2012 12:31 AM
