Old 02-11-2014, 05:12 PM   #15
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Originally Posted by ScionFR-S View Post
Is there anyway we can grease them ? It's super annoying
Before spending time on trying to grease anything, get someone to turn the wheel and have somebody listening in the engine bay, it will be significantly louder if it is indeed there.
Rayme is offline   Reply With Quote
Old 02-12-2014, 02:17 PM   #16
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Ill have somepne look and hear for me but i know for a fact it can only be heqrd inside the cabin and not outside it
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 03-11-2014, 01:43 PM   #17
RPhong
Drives: 2013 Ultramarine FR-S
Has anybody solved this issue?
RPhong is offline   Reply With Quote
Old 03-24-2014, 08:04 PM   #18
JDMenrique
DEEEERP
JDMenrique's Avatar
Im having something similar but instead of squealing it sounds more like a creek. I doesn't sound like it's the steering wheel itself....
JDMenrique is offline   Reply With Quote
Old 03-24-2014, 09:08 PM   #19
roddy
roddy's Avatar
Drives: '13 Ultramarine
Ah, crap! The crickets are spreading...like cancer.
Old 04-12-2014, 12:39 AM   #20
The_Societan
The_Societan's Avatar
Drives: Firestorm FR-S
I lost my power assist the other night... while driving about <10 mph in a parking lot. I heard a beep and my power steering was gone. This happened a couple of times a few months ago, during very cold weather, and it went away quickly. This time, it lasted for over a minute and I could barely pull into an empty parking space. I was about to make an an appointment with my Scion dealer, but I decided to wait and see if it happened again. So far it hasn't. Just a random glitch?
The_Societan is offline   Reply With Quote
Old 04-12-2014, 08:33 AM   #21
troek
troek's Avatar
Drives: 2012 Toyota 86
mine was "sqeaking" as well, althought it was obvious it was a rubbing plastic noise. i have a after market steering hub and the accordion like shroud was just long enough to rub on a little sensor thing on bottom of the steering column. i just cut 1 ring off it and its good to go. it didnt initially do that so im assuming over time something has warped after all the abuse the steering wheel takes, could be an issue with the stock steering wheel as well. its not hard to take off the weel, and at the 6 o'clock position theres a glossy plastic piece that i assume is part of the steering angle sensor that will have rub marks on it if if that is your issue.
Old 01-08-2016, 06:03 PM   #22
monsterspeed
monsterspeed's Avatar
Drives: 2018 Subaru BRZ Performance Package
Fixed this. I just had to follow the steering column under the dash to the point where it enters the floor of the car. There is a rubber boot here, I just played around with this and the sound went away.
monsterspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to monsterspeed For This Useful Post:
aa_chow (02-09-2018), CelicaJoe (02-09-2023)
Old 02-09-2018, 05:37 PM   #23
aa_chow
aa_chow's Avatar
Drives: 2015 FR-S, 2020 Mazda 3 Sport
Wow, thank you!
Just had it happen this week....was driving me crazy!
Sent from my ONEPLUS A5000 using Tapatalk
aa_chow is offline   Reply With Quote
Squeaking noise from wheel oinkoinkpig Issues | Warranty | Recalls / TSB 8 04-26-2014 11:10 AM
Squeaking noise oinkoinkpig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 12-25-2013 04:26 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
Squeaking Noise From Steering Wheel tonytduc Scion FR-S / Toyota 86 GT86 General Forum 4 01-28-2013 07:58 PM
weird plastic squeaking noise (back seats) whyreeto AUSTRALIA 5 09-17-2012 01:34 AM
