#15 | |
Thanks! I had been pouring through some other threads, did not look at the meaty tire thread. To make sure I am understanding this all correctly I can: Buy Coilovers and LCA in order to run 18x8.5+45 on 235/40/18 Fronts and 18x9.5+40 on 265/35/18 Rears Or perhaps run a 255 tire in the rear and avoid getting the other components? I don't like to see lip (poke doesn't really bother me either) so I am starting to think I will just need to bite the bullet and buy the dang suspension. |
#16 | |
Country Boy 4 Life
Good luck! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Daver (10-26-2016) |
#17 |
Drives: 2013 BRZ Limited
I'd been eyeing this set in the +33 front offset variation for a long time, but ended up buying the +45 front offset due to the others being out of stock. I noticed there's hardly any pictures of this setup available here, so hopefully these pictures help others in their decision.
SPECS: 18x8.5+45 / 18x9.5+40 F/R (+ 5mm spacer in front) MPSS 235/40 / 265/35 F/R Factory alignment specs Lowered ~1" front, ~0.75" rear (due to tire rubbing in rear, need to add a bit more camber) ![]()
#18 |
Finally Got em on
![]() ![]() ![]() Big thanks to @ExxelDistributions for the sick deal on Rims, and suspension. Those guys are good peeps! Last edited by Daver; 02-15-2017 at 12:18 PM. |
#19 | |
Drives: 2014 FR-S 6MT Monogram Series
| Scion FR-S with 18x8.5 Gram Lights 57xtremes all around? | IAmNotTheDriftKing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 50 | 11-22-2015 03:36 AM |
| Wheel Directory: Rota RKR 18x8.5 +44 / 18x9.5 +44 | Hindi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 99 | 06-08-2015 08:07 AM |
| Wheel Directory: Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45 | 86 FRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 05-19-2014 12:28 AM |
| Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 | JRoldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-07-2014 08:10 AM |
| FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 | funcheung | Canada Classifieds | 7 | 09-16-2013 05:01 PM |
