#15 |
Thupercharged
Yeah, having maxed out STFT until the ecu adapts is not my idea of an optimal situation.
Going flex fuel next summer with a zeitronix unit.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#16 |
#17 | |
Professional Smartass
Drives: White Out FRS
And the really scary part about this setup is when other people borrow your car. You run the risk of forgetting to tell them not to put fuel in the tank. |
#18 |
#19 | |
PhoneFlash by EcuTeK
There are options outside of the oem ecu programming with Ecutek. Though I believe they are fairly expensive up front costs. Motec could be setup for FlexFuel but at the cost of over of nearly $5000 after the system and FlexFuel kits. I assumed we were only speaking about OE reprogramming systems. I apologize I should have clarified your original question. |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | s2d4 (12-14-2013) |
#20 | |
#21 | |
Thupercharged
If you want to expand on why it wouldn't max the stft and that maybe I got a bad tune your post would be helpful in the context of the thread topic
2013 FRS
#22 | |
it takes a lot to convince this ecu to do something stupid. |
#23 | |
Thupercharged
I was not interested in giving it time for the ltft to settle/adjust, as I don't like to rely on larger than necessary closed loop fueling adjustments I believe the ecu can deal with a range of ethanol content, but I don't have to like how it deals with it when other options are available Perhaps the tune was to blame... I got sent an e85 tune by mistake and suggested it to the tuner who verified that was the issue and an e10 "pumpgas" tune was sent in its place which had much more favorable initial trims
2013 FRS
#24 | |
#25 | ||
In this case, he only runs E85 on the track, and pump gas for street driving. He specifically did not want flex fuel. And I don't think he'll be lending this car out to anyone. So the chances of running on the wrong map are very slim. Quote:
Each owner/situation is different, but most folks I've worked and talked with and are looking to run E85/pump are car enthusiasts who are well aware of the fuel they run in their car and the tune they run on. The switch from straight E85 to pump and back is like a ritual at the pump and is not for the average car owner. Again, flex fuel makes the process idiot proof. - Bob |
#26 | |
Drives: 2013 White Out FR-S
#27 |
I think the major fact that needs to be covered isnt for those running pure on either end but those who have or want the ability to run a mixed ratio. We have our road/race cars running a specific blend reason being is it allows extending mileage in an enduro while getting us a bump in power. We are required to make "X" amount of pit stops but while doing so we must wait a total of alloted time before leaving. Being able to do the race while putting down enough laps without the additional pit stop helps allot. While flex fuel isnt mandatory foe all that doesnt mean it wont serve a purpose. Otherwise Audi, GM, Ford, Etc would never have spent the dollars it took to upgrade and add it to their vehicles. All we did is repurpose it for a performance specific application. Not only EcuTek But COBB, Hondata, Motec & Haltech have done this.
#28 |
| questing on going with a flexfuel tune | yetiFR-S | Engine, Exhaust, Transmission | 3 | 11-22-2013 08:17 AM |
| Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
| Flexfuel | Allch Chcar | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 11-04-2011 12:39 AM |
