| Member's Car Journals Car journals by our members. |
#15 |
Who was it? Not the guy who hadn't had a car for nearly a year?
#16 |
NASA SpecE30 Racer
Nah, he sold his kit to someone else a long time ago.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#17 |
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
I'm not really sure if he had any guages. I'm looking at guages now. I was looking at the Greddy Multi D A guage. but it looks like it is a 62mm guage and that sounds a little bigger then most standard guages. I wanted to put it in the vent so I have the three readings right now I really want to watch. boost, oil temp, and oil pressure. and good mounting suggestions?
#18 |
NASA SpecE30 Racer
You should really want to monitor boost and air fuel ratio. There are mounting solutions for the A pillar, the window defroster vent, the gauge cluster surround, and the dash panel in front of the passenger.
- King Tut
#19 |
So It has been a while since I posted much of anything but I got my kit installed and just got done on the dyno and we turned some nice numbers. All dyno runs were done on a mustang dyno @Infamous Performance with @DeliciousTuning .
First Run - Base Run: 205 hp, 141 ft/lbs Second Run 91 Delicious 8.5 psi: 235 hp, 162 ft/lbs Third Run E85 Delicious 9.5 psi: 290 hp, 198 ft/lbs ENJOY! |
#20 |
Drives: Nissan Primera GT
Are you happy with the last pull there? #'s look good
#21 |
Drives: Sterling BRZ Ltd
Nice, what turbo do you have?
#22 |
I am very happy with the results yielded and it is the @FullBlown Motorsports Stage 1 turbo kit. All the runs were done by @DeliciousTuning on a mustang dyno @Infamous Performance which typically shows less than what you see on a dyno jet. Usually a mustang dyno produces some where between 10% - 20% less which means on a dyno jet it would not be surprising to see me put down numbers between 330 - 360 HP. I plan to get on one eventually just to get a comparative pull because I know there is always argument on the numbers so I will post a dynojet run when I get the chance but even at the power it is at I am super happy and the tune is so nice the car drives so much smoother through all ranges and pulls incredibly well.
#23 |
[ame="http://www.youtube.com/watch?v=Vrz6NwAE2t4"]Toekneehair - Subaru BRZ - Dyno Run Full Blown Turbo Kit - YouTube[/ame]
#24 |
Drives: SWP 2013 Subaru BRZ Limited
So jealous right now. What turbo are you running if you don't mind me asking? Car looks awesome by the way.
#25 |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Working on straightening out the database (Bill accidentally ran the best pull with the dyno recording the run in the file for Bills BRZ). Once I move the pull over to your file, I should be able to print it without the graph listing Bills car as the car on the dyno. I can print it now, but it shows Bills name and license number instead of yours. Data from the pull is correct.
#26 | |
#27 |
We have another FB turbo kit FR-S running a 12psi map. He makes 250whp on CAN91. So, there is more power to be had by pushing the boost up. When I have a spare hour or two I will get the database straight and print/email you the 295whp pull for your records. Glad you are enjoying the car and new power.
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
| Whitefrs's Full Blown Stage 1 base kit build | whitefrs | Member's Car Journals | 9 | 03-28-2013 03:22 PM |
