Old 12-10-2013, 11:51 AM   #15
s2d4
s2d4's Avatar
So the previous owner didn't have a boost gauge to verify either?
Who was it? Not the guy who hadn't had a car for nearly a year?
Old 12-10-2013, 01:35 PM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Nah, he sold his kit to someone else a long time ago.
Old 12-12-2013, 02:29 AM   #17
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
I'm not really sure if he had any guages. I'm looking at guages now. I was looking at the Greddy Multi D A guage. but it looks like it is a 62mm guage and that sounds a little bigger then most standard guages. I wanted to put it in the vent so I have the three readings right now I really want to watch. boost, oil temp, and oil pressure. and good mounting suggestions?
toekneehair is offline   Reply With Quote
Old 12-12-2013, 10:12 AM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You should really want to monitor boost and air fuel ratio. There are mounting solutions for the A pillar, the window defroster vent, the gauge cluster surround, and the dash panel in front of the passenger.
Old 01-18-2014, 04:42 AM   #19
toekneehair
So It has been a while since I posted much of anything but I got my kit installed and just got done on the dyno and we turned some nice numbers. All dyno runs were done on a mustang dyno @Infamous Performance with @DeliciousTuning .
First Run - Base Run: 205 hp, 141 ft/lbs
Second Run 91 Delicious 8.5 psi: 235 hp, 162 ft/lbs
Third Run E85 Delicious 9.5 psi: 290 hp, 198 ft/lbs
ENJOY!
Old 01-18-2014, 08:23 AM   #20
Ninth_Cloud
Drives: Nissan Primera GT
Are you happy with the last pull there? #'s look good
Ninth_Cloud is offline   Reply With Quote
Old 01-18-2014, 09:02 AM   #21
mrk1
Drives: Sterling BRZ Ltd
Nice, what turbo do you have?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-18-2014, 02:45 PM   #22
toekneehair
I am very happy with the results yielded and it is the @FullBlown Motorsports Stage 1 turbo kit. All the runs were done by @DeliciousTuning on a mustang dyno @Infamous Performance which typically shows less than what you see on a dyno jet. Usually a mustang dyno produces some where between 10% - 20% less which means on a dyno jet it would not be surprising to see me put down numbers between 330 - 360 HP. I plan to get on one eventually just to get a comparative pull because I know there is always argument on the numbers so I will post a dynojet run when I get the chance but even at the power it is at I am super happy and the tune is so nice the car drives so much smoother through all ranges and pulls incredibly well.
Old 01-18-2014, 03:03 PM   #23
toekneehair
[ame="http://www.youtube.com/watch?v=Vrz6NwAE2t4"]Toekneehair - Subaru BRZ - Dyno Run Full Blown Turbo Kit - YouTube[/ame]
Old 01-20-2014, 12:12 AM   #24
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
So jealous right now. What turbo are you running if you don't mind me asking? Car looks awesome by the way.
johnb831 is offline   Reply With Quote
Old 01-20-2014, 10:43 PM   #25
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Working on straightening out the database (Bill accidentally ran the best pull with the dyno recording the run in the file for Bills BRZ). Once I move the pull over to your file, I should be able to print it without the graph listing Bills car as the car on the dyno. I can print it now, but it shows Bills name and license number instead of yours. Data from the pull is correct.
Infamous Performance is offline   Reply With Quote
Old 01-21-2014, 11:21 PM   #26
toekneehair
Yea I was just excited to post up numbers and I had the screen shot which I added to the video. 290 to 295 isn't a big difference especially when your tires are spinning loosing traction haha. I think once I get a new clutch in we can shoot for a bit more power. We stopped at 9.5 PSI once the clutch started to slip. I know many have been going to 11 or so PSI and I am a bit tempted to push up the number.. but we are all a little power hungry aren't we lol...
Old 01-22-2014, 04:08 PM   #27
We have another FB turbo kit FR-S running a 12psi map. He makes 250whp on CAN91. So, there is more power to be had by pushing the boost up. When I have a spare hour or two I will get the database straight and print/email you the 295whp pull for your records. Glad you are enjoying the car and new power.
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
Whitefrs's Full Blown Stage 1 base kit build whitefrs Member's Car Journals 9 03-28-2013 03:22 PM
