Old 11-15-2013, 02:17 AM   #15
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by 1086 View Post
So at the minimum, a tune is a must for E85 to work properly/safely?
Yes. The flex fuel kit just simplifies the flashing/map switching process.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 11-15-2013, 02:55 AM   #16
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by CaptainSlow View Post
So, on a related topic, is this upgrade worth the money? I'm looking at the cost of headers, and of course, the cost of the big jump to FI, and it seems like the $950 cost for the whole setup (that is what I was quoted by FA20club for 30whp is a pretty decent ROI, but I just want to be sure before I really commit to it.
If you just want to run straight E85, you don't need a flexfuel kit. All you need is an E85 tune. Ours is free
Shiv
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
Skidrcn (04-23-2015), why? (08-17-2015)
Old 11-15-2013, 07:13 AM   #17
Malt
Drives: 2015 WRX
Shiv
Shiv, I'm really excited about the release of your E85 maps and I found a gas station 5 miles from my place of work that sells it so I'm set there. I do have one question though. IF someone did want the ability to a flex fuel kit in their car so they could swap between 93 and E85 without reflashing, is this something that the OFT can or will support in the future? I'm not sure how the other two flex fuel kits are accomplishing this, but the general idea that I get is they just re purpose a sensor to the ECU for the flex fuel sensor with ECUTek?
Either way, I'm going to most likely run your map after its released to get an idea of mileage with the car on E85. I'd just hate to have to reflash the car each time I go to places that don't have E85 available.
Malt is offline   Reply With Quote
Old 11-15-2013, 10:32 AM   #18
Hawaiian
That guy
Hawaiian's Avatar
If you don't have live map switching you will need to reflash every time. With the ecutek tune I have my pump gas on one map and E85 on another.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 11-15-2013, 01:18 PM   #19
Mrpolarbear
Drives: 2013 DGM BRZ - MT
How cold do E85 starts begin having issues?
Mrpolarbear is offline   Reply With Quote
Old 11-15-2013, 01:27 PM   #20
Shiv@Openflash
Drives: 2013 FRS
We have seen early morning temps (in NorCal) as cold as 45F and no cold start issues. The cranking enrichment table did have to be revised to make this possible. With the stock cranking enrichment table values, the car would stall at the first and second starting attempt
Shiv
Old 11-15-2013, 01:55 PM   #21
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
It was 45 here in Texas yesterday. It refused to start. I had to try 8 times and give it gas before it would fire up. E75. Anywhere under E65 and it cold starts fine, but I was trying to keep the ethanol high because I have a track day tomorrow.
post_break is offline   Reply With Quote
Old 11-15-2013, 01:58 PM   #22
Shiv@Openflash
Drives: 2013 FRS
You'll need to revised the cranking enrichment table. I'm running up to E85 and no issues in cold mornings.
Old 11-15-2013, 02:13 PM   #23
CaptainSlow
CaptainSlow's Avatar
Shiv, I sent you a PM, just so you know. Thanks for all the replies!
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 11-19-2013, 03:29 PM   #24
reeves
Originally Posted by Hawaiian View Post
Originally Posted by arghx7 View Post
How often do you put in E10? Every other tank? Once a month? One time since you initially switched to E85? Or have you literally run only E85 that entire time?
The reason why I ask is because Saab did some pioneering work on turbo [PFI] E85 applications back in the late 2000s. One of the things they found was that running E85 leaves deposits on the injectors, but occasionally switching to gasoline cleans them up very quickly.
I heard sonething similar so I will run a tank of 93 roughly every 5 tanks of 85.
I will be going to FI in the spring and with it I will upgrade my injectors. I'll post photos of my old injectors and plugs when I do.
I initially ran E85 only 60-70% of the time (fillups) my first few months on the E85 tune... after that, I've been on it 90%+ of the time.
Since mid-May, I've had 58 top-offs & 3 partial fillups.. I've only put in 93 octane 4 times during that span (2 times were partial 93 fillups): 2 times in June, once in mid October, and once again 3 weeks ago.
I'd be interested to see how your injectors look Hawaiian.
The hard startups during cold mornings aren't enough to get me off the corn juice... yet. I'll wait to see how difficult the startups get when temps drop to below 40F first.
reeves is offline   Reply With Quote
Old 06-17-2014, 02:55 AM   #25
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Any updates on the potential injector clogging issue? If running E10/E0 gasoline does clean up deposits, how often should it be done?
@Hawaiian @reeves @CaptainSlow @post_break @mikalem @shiv@vishnu
The following thread discusses decreasing the throttle relearn time for those flashing back and forth. I've found the 5x pedal down then on trick worked (post #13). Wasn't the only thing I tried after a new map though. I didn't try steve's method yet.
http://www.ft86club.com/forums/showthread.php?t=39480
unsurety is offline   Reply With Quote
Old 06-17-2014, 05:47 AM   #26
reeves
I've never tried the 5x pedal down method after reflashing. I just drive normally afterwards, the 2 times I've actually had to reflash. I haven't taken my injectors out yet either.. I'll probably replace them at the end of this year when I get close to 60K miles, then we'll see how "clogged" they are. I haven't had any issues so far though.
The Following User Says Thank You to reeves For This Useful Post:
unsurety (06-17-2014)
Old 06-17-2014, 07:21 AM   #27
CaptainSlow
I have not had any issues, but I am running a few weeks on E85, then a week or so on 93...just based on my schedule. I like to switch back to 93 if I have a longer road trip, just because there aren't too many E85 stations around our state, and I don't want to be stranded.
The Following User Says Thank You to CaptainSlow For This Useful Post:
Old 06-17-2014, 09:05 AM   #28
post_break
post_break's Avatar
Every 5 tanks of E85 run a full tank of E10. No clogging.
The Following User Says Thank You to post_break For This Useful Post:
DIY Request- Port Injectors whitefrs DIY (Do-It-Yourself) Guides 37 08-22-2019 11:20 PM
Injectors installation kaybee123 Forced Induction 27 03-08-2016 09:26 PM
injectors and tuning? love 4 boost Software Tuning 8 11-09-2013 07:56 AM
Deatschwerks BRZ/FR-S Fuel Injectors! RallySport Direct Engine, Exhaust, Bolt-Ons 2 09-07-2012 06:29 PM
