Old 06-18-2013, 05:11 PM   #1
Djen
Drives: GT86
poor throttle response
hi could someone help me step by step.. dose someone experience same what I do ?
I just installed CAI and I drive it for half an hour then I disconnect the nagtive battry tinrmal for 20min and then put it on agine I allowed the ECU to reset so the rexults now a Poor acceleration\slow throttle response.. please could someone help me out
Djen is offline   Reply With Quote
Old 06-18-2013, 05:16 PM   #2
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
throttle will always be a bit sluggish after ECU reset or flash. Give it a gas tank and it should settle. ECU needs to get adjusted to the stepper motor in the throttle plate.
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Churg (06-13-2014), funwheeldrive (01-18-2017)
Old 06-18-2013, 05:36 PM   #3
Foobar
SLO NO MO
Foobar's Avatar
Could try Jeff Perrin's suggestion of turning car on without starting the engine, fully press and release gas pedal 20 times, turn car off, turn on without starting again, press and release 20 times again, then start engine. No more ECU reset dead pedal.
Sent from my Nexus 4 using Tapatalk 2
The Following User Says Thank You to Foobar For This Useful Post:
unsurety (06-08-2014)
Old 06-18-2013, 05:46 PM   #4
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
which CAI did you install. from what i understand all CAI will decrease throttle response because they increase top end power only.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 06-18-2013, 06:23 PM   #5
xwd
Like others said, it has nothing to do with the CAI, it's the ECU reset which is causing the throttle lag.
Old 06-18-2013, 06:29 PM   #6
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
does this work? I'm going to try this after work today =) was just rummaging around.
CamryDS is offline   Reply With Quote
Old 06-18-2013, 06:31 PM   #7
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
A CAI may affect the low end power/torque and feel a little more sluggish when the car is trying to move, but as others have said the throttle response is due to resetting the ECU. The computer needs to re-learn.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
Nitro22 (12-04-2016)
Old 06-19-2013, 03:10 AM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, but you only need to do it 5 times. I've posted about this before and I do it every time I re-flash.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Mikem53 (06-19-2013), unsurety (06-10-2014)
Old 06-19-2013, 11:52 AM   #9
Pete
Pete's Avatar
Drives: 22 BRZ
It works. Jeff Perrin told me about that a few months ago and I do it every time I flash now.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 06-19-2013, 12:23 PM   #10
CamryDS
Thanks, I tried it after work yesterday.
- Car set to ON - step on the peddle 20 times or so (full on and full off)
- Turned the car off - stepped on the peddle 20 times or so (full on and full off)
- Turned the car back to on - repeated step 1
- Started the car completely
There was some improvements. Just wondering is there a guide for this?
Old 06-19-2013, 12:40 PM   #11
Foobar
SLO NO MO
Foobar's Avatar
You don't actually need to do the pedal thing (step 2 above). Just turn off the car and turn it back on again before repeating step 1.
I've never seen this published anywhere else but from Pete and a few others who have variations on the theme.
CamryDS (06-19-2013)
Old 06-19-2013, 12:45 PM   #12
CamryDS
Ahh, thanks for clearing that up -- i'll do that again this afternoon
Old 06-19-2013, 05:10 PM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
Reset ECU, turn car to accessory. Slowly depress the accelerator 5 times fully to the floor. Turn on car. Its just so the ECU can register 100% pedal movement. That is also why you get dead pedal for a while if you don't. Doing it with the car off is pointless as the ECU isn't powered up.
This works, 20 times is a waste of your energy!
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
sroby (06-08-2019)
Old 06-09-2014, 08:29 PM   #14
Emyl
Yizusss!!!! Thanks to this post and Kodename47.
I was going crazy with this lag!... Thanks!
Im happy and relax now.
I thought my car was damaged!
Emyl is offline   Reply With Quote
The Following User Says Thank You to Emyl For This Useful Post:
93Targa (02-16-2015)
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
Throttle response delay jay07631 Engine, Exhaust, Transmission 12 07-09-2013 09:41 PM
Throttle response after intake mods Aaron_blatherwick Engine, Exhaust, Transmission 2 05-22-2013 05:18 PM
Does the throttle response improve? pr086 Scion FR-S / Toyota 86 GT86 General Forum 36 12-01-2012 01:06 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
