#15 | |
Drives: dark grey metallic Toyota 86 MT
#16 |
Drives: frs
I have kwv3s and in in addition to the better handling, they ride smother than stock at the recommended settings, which I like very much.
#17 | |
Drives: 2005 Toyota Camry
Without even using them, the pros and cons are sort of overlapping: - lack of upper camber plate (which is both good and bad dependent on user) - 2-way adjustment (again, good AND bad depending on who the user is)... more isn't necessarily better, but if you know how to tune and dial in suspension, you can benefit from this - high quality (high cost) - superior shock design (high cost) etc etc I know lots of people like these coilovers, I used to be down that road with Endless/Zeal suspension for a long time, then moving onto KG/mm coilovers for my S13. The added adjustment of KG/mm versus my Zeal Function B6 (6-way adjustment only) made a tiny difference, but in the end it didn't suit my driving needs. In any case, if you have it figured out then the pros/cons you should already know. -alex |
#18 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
I have had mine on for 1k Plus miles, and i love them. Took some adjusting from the factory settings to get it dialed into what i felt right for Daily/Canyon driving.
Pros: Great stability while turning, Very Adjustable, Right on the money for performance, Great ride height (Plus adjustable like many coil-overs) Cons: No Camber plates/Top hats, Little Pricey(But i'm not cheap but i'm just mentioning it)
#19 |
Drives: Pegasus White 86GTS
No camber plates.
They aren't mono-tube. Very good suspension to own If you want to get low, they will give you a very nice 50mm+ drop.
Pegasus White 6MT got it. :happy0180:
#20 | |
Max height around 10mm less than stock. - Andy |
#21 | |
Living the dream
Drives: Fensport AVO Turbo GT86
#22 |
Our roads here on the east coast are awful. Not sure where you are in the UK but I have family around Salisbury and though its been a while the roads are similar or worse here!
- Andy |
#23 |
Living the dream
Hi Andy,
My Uncle and Aunt live in a small village just outside Salisbury! I live in Worcestershire. I have sent a pm to Racecom Engineering asking for more details about your clubsport coilovers. Dave |
| Pros and Cons of the Rocket Bunny Kit | VroomVroom86 | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 11-07-2014 01:29 AM |
| cons of mushroom filter? | ft86me | Forced Induction | 13 | 10-22-2013 02:37 AM |
| cons of buying online? | chickdigger802 | BRZ First-Gen (2012+) — General Topics | 35 | 09-03-2013 10:42 PM |
| Car Wrap / Foil Wrap : Pros and Cons? | LeBryan | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-25-2013 09:13 PM |
| What are the Pros and Cons of switching to a bigger set of Brakes? | STi88 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 50 | 08-06-2012 02:50 PM |
