#15 |
Drives: C6 Corvette Z06
You may need an o2 spacer on your secondary o2 sensor. Pull the code first though. Great tips from ProTekk
#16 |
Drives: Whiteout FRS
finally got the ODB 2 reader. So the CEL error i was receiving was P0128 (powertrain coolant bellow temperature spec.
I had the car idle for about 10 minutes and received a temperature of 167 degree. I started to drive around and the temperature climbed to around 187. The max temperature i received tonight after 20 minutes of driving was 192.2. My coolant level is normal. Do you think i should clear the CEL with the application or have the dealer check it out? Im almost leaning towards the dealer on this one.
IG: ft86carbon |
#17 |
Drives: frs
clear it
#18 |
CE; DEALS SAYS IDK. P0134,P0030,P0031
FIRST OF THANK YOU Long story short. I have a tune from ecutek stage 1 by perrin and a catback exhaust.
Incident record. -catback- installed 2 month ago before CEL -ecutek flash 1 month ago before CEL I took to the dealer and told them everything i did to my car since i didnt really care about their warranty and it's the only place i can trust during my undergrad career. I was told by the lead tech O2 sensors(rear) was not sending or receiving signal. I tried flashing back to stock, clear codes and flash to stage 1 clear. but none of them works. I was ensured by tech at subaru that its very rare that O2 sensors. I was told by dealers not to buy a new sensor but instead go to perrin and ask for a new set of map I bought. clearly that didnt do anything since Perrin folks never have to tamper with that part. My questions is , is it possible that I have a broken O2 sensor in the rear? since catback installation did not require touching them. How would that be broken during installation. and after the dealer cleared my code instead of havin P0030 and P0134, I have P0031. is it possible that my tuning is just messed up? I looked up all the codes and they seem pretty similar to each other. all related to the heat circuit O2 ![]() THANK YOU GUYS |
#19 |
I believe my issue was a faulty O2 sensor. I ended up not clearing the code. About 3 days after using the torque application, the CEL went away. I did end up taking it to the dealer. Dealer said even though i had the exact error code, they could not diagnose the CEL without it being on. kind of a waste of time.. but the CEL has not come back on since.
IG: ft86carbon |
| Any NY'ers install catless front pipe? | ShoNUFF | NY / NJ / CT / PA | 19 | 01-04-2015 08:30 PM |
| Catless front pipe install? | bdanisi | Southern California | 7 | 08-22-2013 08:26 PM |
| Assistance on DIY front pipe install. | Osiris | DIY (Do-It-Yourself) Guides | 3 | 04-18-2013 10:31 PM |
| MXP EXHAUST and FRONT PIPE FRS BRZ in stock ready to install or ship | AMPLIFIED MOTORSPORT | Engine, Exhaust, Bolt-Ons | 0 | 11-08-2012 09:09 PM |
