#15 |
Drives: 2013 FRS Asphalt
last time I seen you I think you were running 225s on stock rims. and I agree for those the pressures are to low. we have one event left in November 9th and tenth come down for the weekend it will be fun.
also I know you think the surface jacked your alignment last time but in 3 years of using this site I never had that issue. if you come down on Friday I can give you a tour of volition. you would have fun.
2013 Scion FR-S AT Picked up 5/30/2012
#16 | |
#17 |
Drives: '13 BRZ Ltd
Cool video.
Lot of movement of the swaybar/chassis bushing, especially considering the small-ish range of motion of the swaybar to begin with. Also interesting that the subframe doesn't move that much laterally, it seems to be mostly vertical. I installed subframe bushing inserts on my GR STI and it seemed to really make the rear end more responsive and predictable. |
| The Following User Says Thank You to Wepeel For This Useful Post: | Racecomp Engineering (10-22-2013) |
#18 |
i'm sorry, what?
Drives: Canada
DAT CROSSMEMBER FLEX
i'm almost willing to get dumped into STX just to outfit the car with all the possible bushings, holy crackerjack.
#19 |
Drives: EVO
Interesting video and interesting to see your pressure/camber settings. A soft tire and stiff suspension seems kind of basackwards to me though as the tire is largely undamped. Just from experience, take a well damped car with high spring rates and through soft tires on it and it will be bouncy as hell.
I can't tell if there is actual subframe flex or if it's just the large amount of bushing flex causing it to look like subframe flex. There are definitely a couple spots where it looks like more then just bushing flex though. |
#20 |
Who else makes bushings for the rear other then whiteline? After they screwed everyone with the com-c's top hats I don't want to give them anymore money. They didn't even test them other then seeing if they mounted up. I can idmagine it was the same with the bushings considering how fast they got them out. I just don't trust them.
#21 | |
Drives: Nissan Versa
Edit: I think Energy Suspension also just finished their bushing package for the 86's according to their Sept. 30th Facebook entry. |
#22 |
Drives: Ultramarine FR-S (MT)
Wow, tons of slop everywhere! You've convinced me to get some inserts for the rear
#23 | |
Ha thats not even the point of the video. Just showing what the RCE springs/Konis look like when at work.
#24 | |
Actually the opposite. I was having issues with the car wanting to step out on me when hitting the bumps and becoming unsettled in the rear with a softer setup. As soon as I went to a stiffer setup the car was much more stable. Everything is just damped better. Rebound is better ect. I don't know if its a combo of the stiffer springs all around or the shocks helping. Since I never had them on with out each other cant really say.
#25 | |
#26 |
Drives: FRS, IS300, 911sc
#27 | |
I run the tire so close to the spring perch to get that much camber most people would be un comfortable with it. If the bolt slipped there could be issues. I can only fit my credit card and drivers lisence in between the rim and spring perch. That's with my 245/40 rs3s on the rpf1 17x9 +35 rims. If I had the 45s I'd be screwed.
| The Following User Says Thank You to feldy For This Useful Post: | Turbo Den (10-25-2013) |
#28 | |
Drives: 2014 Subaru BRZ
| DIY: Cutting OEM struts (front) for Koni Yellow inserts | mit_peid | DIY (Do-It-Yourself) Guides | 25 | 06-20-2014 12:16 PM |
| Review: RCE Yellow Springs and KONI shocks | Grimlock | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 81 | 03-27-2014 10:58 AM |
| F/S: Koni Yellow struts and H&R Supersport springs $650!! | MountainManFR-S | Brakes, Suspension, Chassis | 4 | 07-02-2013 07:06 PM |
| -Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! | OrbitalEllipses | Mid-Atlantic | 21 | 06-14-2013 12:10 PM |
| Koni inserts or wait for full Koni replacements | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 05-18-2013 05:48 PM |
