Old 10-20-2013, 09:55 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
RCE Springs Koni Yellow inserts Video at work.
Here is video of some RCE springs and Koni yellow inserts at work. @Racecomp Engineering
[ame]http://youtu.be/4PToOkNim7I[/ame]
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following 5 Users Say Thank You to feldy For This Useful Post:
Anthonytpt (10-21-2013), Burrcold (10-20-2013), clickfiveZ (10-22-2013), fstlane (10-20-2013), Wepeel (10-22-2013)
Old 10-20-2013, 10:01 PM   #2
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Looks like that exhaust hanger gets a pretty good workout
Wise is offline   Reply With Quote
Old 10-20-2013, 10:19 PM   #3
Squishy86
Squishy86's Avatar
Drives: Your Car
Lol @ the cone in 1:06.
Squishy86 is offline   Reply With Quote
The Following User Says Thank You to Squishy86 For This Useful Post:
Old 10-20-2013, 10:26 PM   #4
Burrcold
Drives: Subaru BRZ Limited
That video ruled!! Lol'd at the cone too. That exhaust hanger looks like it's made out if jelly.
Old 10-20-2013, 10:35 PM   #5
feldy
feldy's Avatar
That's the Perrin Hangers and perrin catback. @PERRIN_Chris These do like to shake a lot huh
Old 10-20-2013, 11:16 PM   #6
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Fail on the cone lol. Great video though. What settings u on
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 10-20-2013, 11:55 PM   #7
feldy
feldy's Avatar
front and rear on the konis 1 full turn from full stiff. We run on concete but I have ran this on blacktop and asphalt.
28 psi front
25 psi rear
245/40/rs3s on 17x9 rpf1s.
-2.5 camber up front
-1.9 camber rear
toe a little out in the front a little in on the rear.
Old 10-21-2013, 10:05 AM   #8
Very cool!
You can see how much the rear subframe moves around.
Those tire pressures are awfully low...
- Andy
Old 10-21-2013, 11:07 AM   #9
feldy
feldy's Avatar
Those tire pressures are spot on if you don't over drive the tires.
This weekend I ran the rears at 24 psi. Remember this is autocross not track days.
I got 204 runs and about 4k street miles on these. on the street I run them at 33 psi all day.
Right size rims helps a lot and alignment and the driver.
These are 245s on 17x9 rims. So the shoulder has no pinch and a very slight stretch keeping the sidewalls more stiff. Last year when I ran 225/45/17s on my stock rims I had to run them at 35 psi. When I was driving my FWD car on RS3s I had to run them at 40psi in the front not to roll over.
Andy I will be doing another video with your tarmac prototype springs in the spring.
Originally Posted by Racecomp Engineering View Post
Very cool!
- Andy
The Following User Says Thank You to feldy For This Useful Post:
Racecomp Engineering (10-21-2013)
Old 10-21-2013, 04:46 PM   #10
Dezoris
Dezoris's Avatar
28 psi front
25 psi rear
-1.9 camber rear
I run a very similar wheel tire setup and would never run the RS3 that low in autox. I understand you are trying to get the tires to roll to maximize that camber but I think you need less camber and more pressure to be honest.
Whenever I dropped below 30PSI on -2.0F it went from grip to slop. (autox)
I like the video a lot it shows two things, as mentioned by RCE subframe movement and sway bar load.
Old 10-21-2013, 06:50 PM   #11
The video reminded me of this one of Aussie V8 supercars. This is a front wheel obviously.
Completely not a comparable car/situation, but just fun to see.
V8 Supercars run a lot of camber, very stiff suspension, and soft tire pressures (in the same range of @feldy or softer). I don't know much else about the cars. But...cool video.
[ame="http://www.youtube.com/watch?v=1SFAt9cqZyU"]V8 Supercars 2009 Hidden Valley Jamie Whincup Tyre Cam - YouTube[/ame]
- Andy
Old 10-21-2013, 07:49 PM   #12
feldy
feldy's Avatar
Some of its just driving style. I know a ton of str guys that run the same kind of pressures I do. what works for me not work for you. for me I found a setup that is predictable to my driving style 100 percent of the time no questions. I took one ftdi event this year and the car was not sloppy at all.
Old 10-21-2013, 07:56 PM   #13
Dezoris
Dezoris's Avatar
Maybe you are right I just feel like those side walls are not stiff enough for those pressures. Guess its an excuse to hook up again for more autox to test!
Old 10-21-2013, 08:13 PM   #14
leon78
leon78's Avatar
Drives: 13 Whiteout
Cool vid...I have a taller side walls (225/50-16) but I find 35 F is the lowest I can go before to much roll over.... and 32 R w/ almost no roll over on my RS3's.
Seeing this vid also remindes me I need rear sub frame bushings.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
DIY: Cutting OEM struts (front) for Koni Yellow inserts mit_peid DIY (Do-It-Yourself) Guides 25 06-20-2014 12:16 PM
Review: RCE Yellow Springs and KONI shocks Grimlock Suspension | Chassis | Brakes -- Sponsored by 949 Racing 81 03-27-2014 10:58 AM
F/S: Koni Yellow struts and H&R Supersport springs $650!! MountainManFR-S Brakes, Suspension, Chassis 4 07-02-2013 07:06 PM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 05:48 PM
