Old 12-20-2013, 02:23 PM   #15
ntaphse
Drives: beater
I got some good questions on PM so I'll add them here.
1. Does it switch quickly from one mode to another? (oil temp, far, boost, water temp, etc) Cause it says in the install pdf it takes 5 secs meanwhile on the videos on other cars it is very fast. So I am confused.
Answer: It switches instantly, I have never seen a delay.
2. Is the socket to the obd port exposed same as scan tool?
Answer: Yes it's the same socket as where you would plug in a scan tool. It is to the right of the steering column just under the dash, very easy to access. The gauge has a low profile plug so it does not hang down. This was one of my concerns and I was glad that they addressed it.
3. Lastly, I'm on FI and plan to only use this as my only gauge. In your opinion is it useful to have?
Answer: I also wanted the gauge for FI. I have the Innovate supercharger so I wanted to keep a close eye on everything. P3 has an added boost sensor that I got but have not yet installed. The factory MAP sensor only reads like 5 psi I think, so you might want the additional sensor. I frequently monitor AFR, water and oil temp, IAT, etc to make sure the car is happy. You can check a lot more, I'm sure you have seen that in the manual.
ntaphse is offline   Reply With Quote
Old 12-20-2013, 04:59 PM   #16
cfusionpm
Drives: Firestorm 6MT Scion FR-S
That's pretty amazing, but $400 is a bit much for me. I get the same results (or better) with my phone mount and the Torque app. Granted, it doesn't look nearly as clean or nice....
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 12-21-2013, 06:33 PM   #17
ntaphse
Drives: beater
It's also worth noting that temps are recorded in the background, so if you're watching AFRs for example you can toggle over to air or oil temp and hit the peak button to see what your highest temp was.
Old 02-10-2014, 12:49 PM   #18
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I just installed this on my car and it's seriously impressive. To save cluttering things up here, I wrote a little blurb on it here with some images.
http://www.ft86club.com/forums/showthread.php?t=57858
I wish they made these 10 years ago when gauge pillars were popular. I would have had one then!
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 02-11-2014, 05:47 AM   #19
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I also did some video etc with this Guage. I do have to figure out how to get it working with FI however come spring/summer.
http://www.ft86club.com/forums/showp...&postcount=103
Old 02-11-2014, 12:00 PM   #20
ntaphse
Drives: beater
Not much to do to make this work with fi. If you're running low boost like 5-6 psi the map sensor will read boost up to this level. I just installed a 69 mm pulley on my Innovate supercharger and it hits like 12 psi now so I installed the p3cars analog boost sensor and switched the gauge to monitor that instead of showing map sensor data through the ecu.
The Following User Says Thank You to ntaphse For This Useful Post:
OICU812 (02-11-2014)
Old 02-11-2014, 12:20 PM   #21
ZionsWrath
Thanks
ZionsWrath's Avatar
Torque is a great app, i enjoy it on my stock car. If you actually modify your car and really need to see some real time data, gauges are where its at. This may not be as good as having multiple individual gauges but fit and finish is expensive.
I'd say this is a happy medium between a torque app windshield mount with your phone and A pillar gauge pods.
Old 03-18-2014, 11:05 PM   #22
Justkiz
Drives: WRB BRZ
I just installed this gauge and it doesn't turn on at all.
I checked the obd2 port and it works with other devices so it is not a fault of obd2 port.
any help or tips please.
Justkiz is offline   Reply With Quote
Old 03-19-2014, 12:06 AM   #23
sirisvirus
Drives:
👍 looks clean
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 03-24-2014, 08:57 PM   #24
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Can anyone advise how to get the original vent out? Like an idiot I used a screw driver to remove the inner trim ring and bent and scratched it. Now I need to buy a new one and I still don't know how to remove it. Does anyone have an unmarked one they want to sell? Any advice is appreciated, thank you.Name:  ImageUploadedByTapatalk1395705463.882520.jpg
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 03-25-2014, 01:45 AM   #25
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Originally Posted by jjkerr626 View Post
Can anyone advise how to get the original vent out? Like an idiot I used a screw driver to remove the inner trim ring and bent and scratched it. Now I need to buy a new one and I still don't know how to remove it. Does anyone have an unmarked one they want to sell? Any advice is appreciated, thank you.Attachment 71759
The whole vent including the silver ring should pop off together. I remember just using my fingers to pop it off.
You should invest in a plastic removal tool set. Lots of them on Amazon. Makes removing interior stuff really easy
HRTROB is offline   Reply With Quote
Old 03-25-2014, 03:31 PM   #26
jjkerr626
jjkerr626's Avatar
Yes thank you I did manage to get it off and fix my plastic with a heat gun. I will definitely get a trim tool in the future. Here is the completed install.Name:  ImageUploadedByTapatalk1395772273.271691.jpg
The Following User Says Thank You to jjkerr626 For This Useful Post:
MJones_RB (10-07-2019)
Old 04-22-2014, 12:58 PM   #27
pleong
Drives: 2013 Whiteout FR-S
how accurate is this?
pleong is offline   Reply With Quote
Old 04-22-2014, 07:32 PM   #28
ntaphse
Drives: beater
As accurate as your ecu? The reading a come straight from the obd2 port.
Gearbanger (08-29-2016)
PTUNING: ATI 60mm Vent Gauge Pod - NEW! ptuning Interior Parts (Incl. Lighting) 0 09-19-2013 04:23 PM
WTB: P3CARS FR-S BRZ Integrated AC Vent Display Gauge GTB/ZR-1 Want-To-Buy Requests 0 09-15-2013 04:43 PM
ATI vent pod for gauge sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 2 08-30-2013 10:49 AM
Anybody local have a P3Cars vent installed? Pneub Southern California 8 08-14-2013 04:33 AM
