Old 09-14-2013, 01:22 AM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by brz2013 View Post
All solved.... Special thanks to element tuning and sportsguy83
What was the problem and what was the solution? Share with the forum.
Old 09-14-2013, 02:32 AM   #16
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Nice to see you guys recommending a VTA catch can. I also love that gold wrapping on your intake pipe. Did you do any before or after testing to see if it helped? I have considered doing it to mine.
Well much of my experience comes from racing boxer motors in our STi and when you increase the size of the turbocharger you just tax the oem crankcase ventilation so I knew the same would apply to the FRS/BRZ. Also I tested the PCV valve and it cannot handle any boost and if you don't remove it you'll restrict crankcase ventilation (since in NA form suction from the intake pull s excessive crankcase pressure. In my eyes there is no other alternative when boosting that is better.
The gold reflective heat tape has been around in racing for years. It's been part of our racing program for a long time and the difference is amazing. Pull off the race track, touch a charge pipe, and you willl burn yourself, but touch the gold wrapped pipe and its only warm to the touch.
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
Sportsguy83 (09-14-2013)
Old 09-14-2013, 02:45 AM   #17
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
The avo oil pump was not perfectly sealed so we fixed that...installed a Cusco catch can and vented the can to atmosphere...so far it seems like the problem is solved. No more oil is being drawn up from the reservoir so I can only assume the pump wasn't functioning properly when not perfectly sealed.
brz2013 is offline   Reply With Quote
Old 09-14-2013, 01:31 PM   #18
M1K3
M1K3's Avatar
Drives: vrooom...
Could you please elaborate on what exactly you mean by "not perfectly sealed" so that others will not make this same mistake. Was it the oil lines not being sealed or the pump/plate not mated to the back of the head properly or the pump mechanism not being aligned correctly to the rotating clip inside the head causing the pump not to actually pump the oil out of the reservoir? Thanks
M1K3 is offline   Reply With Quote
Old 09-14-2013, 04:38 PM   #19
brz2013
brz2013's Avatar
The plate was leaking so we took it off,re sealed and let it dry for 24 hrs. Everything is working now. I would say to anyone to just make sure to let it dry for long enough before driving
The Following User Says Thank You to brz2013 For This Useful Post:
M1K3 (09-15-2013)
Old 09-14-2013, 05:19 PM   #20
OrbitalEllipses
Drives: Attitude
He thoroughly tested it, up to and including burning the car down.
Old 09-14-2013, 07:34 PM   #21
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I didn't want to bring it up, haha.
Old 09-15-2013, 01:07 AM   #22
Element Tuning
I think the gold foil survived
Old 10-19-2016, 12:03 PM   #23
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Pardon me for reviving this old thread, coz I was wondering if the Prova T-Rev would help. My car have been puking oil all over the track with AVO catch can vented out to atmosphere. Currently running the AVO turbo kit as well.
Prova T-Rev
http://www.prova.co.jp/products/inta...000001zh5.html
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Bluetooth issues? zoomzoomers Electronics | Audio | NAV | Infotainment 12 04-27-2013 03:35 AM
Anybody Have Zero Issues? Don Ivey Scion FR-S / Toyota 86 GT86 General Forum 129 03-25-2013 02:14 PM
91 Octane issues? tokiokun717 Northern California 17 02-01-2013 03:21 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 09:15 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 04:41 PM
