Old 08-31-2013, 08:28 PM   #15
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Open loop when cold, closed once warmed up. This was my thinking as well. On normal vehicles, there are triggers (various temperature sensors) that'll switch it over. I just remember mad_sb saying that our cars run in open loop way too long I believe. I'm just wondering...if it's running pigrich, it's not taking in the air volume expected. Intake cam angle or throttle open % change, idle to idle?
Nightbringer is offline   Reply With Quote
Old 08-31-2013, 08:54 PM   #16
jamesm
i've observed the switch from open loop to closed loop on cold start. this is the exact moment that the load goes from crazy high (80+%) to normal (20-30%) and the idle settles down. the hunting up and down bit happens in closed loop after the switch.
Old 08-31-2013, 10:49 PM   #17
Ross
Drives: 85 corolla gts
Can you post a log up from cold start. Curious to see a few things, timing, air fuel ratio, commanded cam timing, as well as trims when it switches over into closed loop.
Ross is offline   Reply With Quote
Old 08-31-2013, 11:43 PM   #18
FA20Club.com
Drives: 2013 White Out FR-S
sounds like someone dinked with a table they didnt have to cause on all the cars ive tuned so far have yet to come across anything like this. sounds also like you maf scaling is off. you should have that much issue dialing in these setups. i spend more time building and adjusting ignition values while fine tuning than anything else.
FA20Club.com is offline   Reply With Quote
Old 09-01-2013, 10:17 AM   #19
jamesm
I'm going to gather some in logworks format to share once my ot-2 shows up in a couple days. The ones I have now are from techstream. I can send them to you to review if you have the software.
Old 09-01-2013, 11:43 AM   #20
1stGenBRZ86
1stGenBRZ86's Avatar
this may be completely incorrect, but maybe something is possibly making your car go through a throttle body relearn procedure every time you start the car? I know this is a common issue with DBW toyotas after changing the battery.
1stGenBRZ86 is offline   Reply With Quote
The Following User Says Thank You to 1stGenBRZ86 For This Useful Post:
jamesm (09-01-2013)
Old 09-01-2013, 01:15 PM   #21
mike the snake
When you refer to "load", what are you talking about here? I'm still learning about our fuel injection systems. I still don't know what "trims" are either.
Old 09-01-2013, 01:19 PM   #22
jamesm
Load is one of the parameters an engine uses to calculate fuel and ignition timing. It's pretty much a function of rpm and throttle input.
At very high rpm with the throttle barely open there is very low load. At low rpm, wide open throttle load is very high. Think of it as a measurement of how much work you're asking the engine to do.
Trims are offsets that the ecu applies to the base fuel tables based on sensor feedback. These are 'learned' or cached over time. High trims are bad.
Old 09-01-2013, 10:59 PM   #23
mike the snake
So how is there any load at idle? You said your load goes from high/80% to low when the idle settles. Trying to grasp/visualize this.
Thanks for explaining.
Old 09-01-2013, 11:02 PM   #24
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
It does have an act streetlite flywheel. The idle, when it's settled, is around 900rpm. They raised it to accommodate the flywheel when the clutch was installed I believe.
@mad_sb have you found anything in your investigation into the ecu that may help understand what's going on?
I lied my idle is locked in between 980-930
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 09-02-2013, 12:26 AM   #25
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Maybe it's something tied to the warm up phase. I'm guessing you're on pump not 85?
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 09-02-2013, 12:22 PM   #26
jamesm
I believe the load is so high because its holding the throttle plate open to stay idling at such a rich afr. It smokes during this period as well.
Old 09-02-2013, 12:22 PM   #27
jamesm
Yes I'm on 93 pump gas. Haven't tried e85 yet.
Old 09-02-2013, 02:18 PM   #28
Hawaiian
That guy
Hawaiian's Avatar
@JuniorAWD any thoughts?
Ultramarine mt FR-S
P&L stage 1 turbo
Treadstone Performance Turbo Kit Update! kmbkk Forced Induction 277 01-16-2020 11:15 PM
BRZ + Supercharger = ??? 1/4 mile girlracer Forced Induction 38 09-11-2014 11:28 AM
Turbo Market and Technology Update circuithero Forced Induction 9 06-26-2013 08:27 AM
10,000 mile update jeebus BRZ First-Gen (2012+) — General Topics 23 05-28-2013 06:59 PM
YES! AWD Turbo BRZ in the works for sure!!! ngabdala BRZ First-Gen (2012+) — General Topics 155 06-25-2012 09:15 AM
