Old 08-13-2013, 06:14 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Hallman Pro MBC or Grimspeed MBC would probably be the best solution for you. Just place it inline on the vacuum line running to your wastegate.
Old 08-13-2013, 06:23 PM   #16
jamesm
^ yep. I've used hallman pros for years with great results. ball and spring type controllers like the hallman tend to spool a bit faster and are a bit easier to adjust than the bleed valve types.
Old 09-10-2014, 09:34 AM   #17
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
I thought you didn't need to use a mbc if you were going to run spring pressure
Scavanger is offline   Reply With Quote
Old 09-10-2014, 09:44 AM   #18
Dream20b
Y u do dis?
Holy dead thread bump batman.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 09-10-2014, 04:54 PM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Who said that you did need to?
Old 09-10-2014, 05:20 PM   #20
Scavanger
Scavanger's Avatar
Honda budy
strong odor @ higher rpm's mRdeMs83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 91 05-31-2021 08:07 PM
Octane booster: 91 to 93 or higher? mike the snake Forced Induction 18 08-13-2013 08:54 PM
Where can i get fuel higher than 91? XPR Small Block Northern California 22 03-24-2013 09:56 AM
Does the higher side of the K&N drop in filter go Liquidsnake Engine, Exhaust, Transmission 2 03-10-2013 11:18 PM
What you want under the hood of a higher performance OEM variant of the AS1? MrVito BRZ First-Gen (2012+) — General Topics 26 12-26-2011 11:07 PM
