Old 08-07-2013, 08:20 AM   #15
defylogik
Track Junkie
Drives: White FR-S
Originally Posted by BlaineWasHere View Post
I bought the ARP studs for WRX, they can be found here:
http://www.rallysportdirect.com/ARP-...2-2011-WRX-STI
I'm just using Blox aluminum/open ended lugs. They are about $70-80 for a set. Mine look like crap now but they are light and I don't see metal shavings during tire changes with this combo. I am using anti-seize also.
I have had mixed luck with ARP extended studs (2+ years using them), after about 6mo worth of use they would cross thread and cause the lug nut to sieze.
I never could determine if it was from the heat, or from the lug nuts themselves. Perhaps some sort of expansion issue between the hardened stud and the softer lug nut. Stock subaru lugs i've gotten 4 years before one stripped/siezed.
One thing i noticed - not using an impact to remove the nut from the stud greatly improved the life of the stud. Keep this in mind, they seem to be a lot less tolerant to a heavy hand (impact).
-Scott
defylogik is offline   Reply With Quote
Old 08-07-2013, 08:59 AM   #16
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by Razz View Post
I would never use spacers due to wheel weight.
Set up your car properly, not mickey mouse.
There are more reasons than a "mickey mouse" setup to run a spacer, and there is nothing wrong with running one if it is utilized properly.
We ran, and the car owner still runs, a 1" spacer on the rear of the Soltice, this allows the car to use the exact same wheel and tire combo front and rear so we can rotate the tires without having to dismount and remount at events. Saved a lot of unnecessary tire wear.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following User Says Thank You to Sccabrz192 For This Useful Post:
BlaineWasHere (08-07-2013)
Old 08-07-2013, 10:40 AM   #17
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
-Scott
Thanks for the heads up! I never use an impact on my lugs period so hopefully they last longer than 6 months!!!!! I'm using aluminum lugs which should be softer than the studs as well as antiseize on the threads.
Old 08-07-2013, 11:07 AM   #18
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
Originally Posted by Sccabrz192 View Post
The OE lugs suck, replace them ASAP.
I've had issues, Simmons has had issues, Holly broke 2 or 3 herself as well. It's not you. They are crap.
I've broke 6.
I win.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 08-07-2013, 01:32 PM   #19
defylogik
Track Junkie
Drives: White FR-S
Ha yeah, i wish you the best of luck
It didn't bother me too much that they died at 6 months, since thats about how long subaru wheel bearings/hubs usually last with track abuse
Old 08-07-2013, 01:46 PM   #20
qoncept
qoncept's Avatar
I bought ARP studs and have 5mm spacers but I haven't gotten around to an alignment that will need them yet. After changing tires for 6 events I've had no issue with my stock studs, though.
qoncept is offline   Reply With Quote
Old 08-15-2013, 09:45 AM   #21
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
Yea, avoiding the impact gun I think is key. I was only using my DeWalt drill w/socket on my stock studs so I doubt that was the issue with killing them. I think I'm going to avoid the situation altogether with the new studs and get a nice 4 post lug wrench to make spinning them off a breeze. No power needed that way.
mpicher is offline   Reply With Quote
WTB: Spacers abutterman Wheels and Tires 3 05-12-2013 06:11 PM
Spacers recomendation, please! kombatlion Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-25-2013 05:21 PM
Spacers and Strengthening Snozzberries Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 04-02-2013 11:42 AM
Will WRX (GD) top hat spacers work on the BRZ? chim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-12-2013 08:56 PM
30 mm spacers possible? Maps316 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-08-2013 04:14 AM
