Old 07-17-2013, 04:54 AM   #15
eckoflyte
Drives: Toyota 86 GTS
Originally Posted by onefasazn View Post
I know Whiteline has universal endlinks with differing length center sections. Just measure what length you need and give them a call.
Thanks. I did a quick google search for their universal endlinks and it turns out they make a bunch of end links with different lengths I can choose from all of which fit the FRS (12mm bolt)! Awesome, at least I know my problem is solveable.
eckoflyte is offline   Reply With Quote
Old 07-17-2013, 04:56 AM   #16
eckoflyte
Originally Posted by simpleisbest View Post
Can't you adjust those control arms for more clearance?
You'd have to increase caster to bring the arm forward and away from the swaybar, but in that picture I already have it on max caster setting.
Old 07-17-2013, 04:57 AM   #17
eckoflyte
Originally Posted by RiskyTrousers View Post
Is this at full droop? Have you checked clearance with the car on the ground?
Sent from my Nexus 4 using Tapatalk 2
Full droop or not, the swaybar should not come into contact with the arm throughout the wheel's full range of travel.
Old 07-17-2013, 07:46 AM   #18
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Adjust those pimp control arms until things clear. An extra degree or two of caster should do the trick.
celica73 is offline   Reply With Quote
Old 07-17-2013, 07:47 AM   #19
celica73
x
Old 07-17-2013, 07:48 AM   #20
eckoflyte
already on max caster. probably sitting at 7-8 degrees (whatever robispec advertised as the max range was). Cannot adjust any further
Old 07-17-2013, 07:50 AM   #21
celica73
Damn. It was worth a shot.
Old 08-02-2013, 03:25 AM   #22
eckoflyte
Just to update this thread, the solution was straight forward. Whiteline end links worked perfectly with it allowing an adjustment of 5cm shorter than OEM which was more than enough to clear the control arms. Thanks all
Old 08-02-2013, 06:49 AM   #23
celica73
Now tell us about the Ohlins.
Old 08-02-2013, 09:14 AM   #24
eckoflyte
Haha, I've been taking my time doing the whole suspension installation at home over the last few weekends. Car is still waiting to be mounted with the new rims and tyres before I get an alignment. I'll have to reserve my performance judgment until I've driven on them spiritedly. I can say however it is still stiffer than OEM despite what many will say about how comfortable they are. However I've had Japanese Ohlins PCV in the past and they were horridly stiff on poor Australian roads and these fair much better. Once you go Ohlins, you don't go back.
Password:JDM Ultimate Adjustable Sway Bar Links Subaru BRZ / Scion FR-S *Group Buy* password:jdm Groupbuys 119 01-28-2015 06:22 PM
Ground Control Complete Coilover Suspension Kit and Adjustable End Links Eric1855 Brakes, Suspension, Chassis 12 05-26-2013 12:02 AM
Ground Control Swaybar Endlinks GC_Adam Brakes, Suspension, Chassis 6 01-02-2013 01:08 PM
Setting adjustable sway bar links Im_SPEED Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-01-2012 09:12 PM
