Old 07-11-2013, 10:32 PM   #15
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
You sure you can call this a review?...
Anyway how much camber does it actually low for other then doloren spec which really is loads of +camber.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline
Old 07-11-2013, 11:35 PM   #16
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Enough negative camber to make someone king of the stance crowd if they wished.
Can also pull it back in a ton if you want. These style of arms allow for full range of camber adjustment.
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
DriftEightSix (07-11-2013)
Old 07-12-2013, 01:49 AM   #17
wheelhaus
wheelhaus's Avatar
Originally Posted by Brzzee View Post
So do the pillow balls used by Cusco meet with your criterion?
I can't say; I've not used pillowball control arms in any of my cars. Cusco is typically good quality, albeit often overpriced... So I'd have to guess their pillowball is as good as anyone else could do.
Edit- I just noticed Cusco uses a boot around the pillowball joint, which is a superb addition for protection from the elements.
wheelhaus is offline
The Following User Says Thank You to wheelhaus For This Useful Post:
Brzzee (07-12-2013)
Old 07-12-2013, 03:00 AM   #18
OrbitalEllipses
Drives: Attitude
RacerX will put a dust boot on your heim/rod end/pillowball for a pittance as well.
OrbitalEllipses is offline
Old 07-12-2013, 07:38 PM   #19
empower-auto
Kouki-Monster
empower-auto's Avatar
Originally Posted by FT-86 SpeedFactory View Post
If you set the adjustment out before you install it and then just use the one section to adjust it isn't bad at all. Easy to get a wrench in there.
If you leave it how they come out of the box, then yeah they are a pain.
Out as in more negative than desired? Please explain in detail because I need to do this asap
Rich Anderson
EMPOWER AUTO
empower-auto is offline
Old 07-12-2013, 11:06 PM   #20
FT-86 SpeedFactory
I'll have to get a photo, hard to explain. Won't be back till Thursday to the shop myself though.
Old 02-16-2015, 03:32 PM   #21
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Cant find any actual reviews or firsthand experience on these. Is anyone running them?
Flat Black VW is offline
Old 02-24-2015, 03:55 AM   #22
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
I'd like to know the same. I'm thinking about trying these out on my next purchase.
JimmyMac is offline
Old 02-24-2015, 10:11 AM   #23
was385
Drives: MT WRB BRZ Limited, 2007 911s
I'm not sure what kind of review you're looking for from these. It's a pretty standard design for aftermarket LCAs and won't do anything substantially different than most others.
was385 is offline
Old 02-24-2015, 11:53 AM   #24
JimmyMac
JimmyMac's Avatar
Probably a review that says, "Stay away from these they suck!" Or a review that says, "They work great and do the job. No problems out of them."
JimmyMac is offline
SPC Lower Control Arms(Old and New) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 07-10-2017 09:58 PM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
WTB - Adjustable Rear Lower Control Arms swift996 Want-To-Buy Requests 0 06-12-2013 12:23 PM
FS: SPC Adjustable Lower Control Arms kenward Brakes, Suspension, Chassis 2 04-29-2013 08:58 AM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 05:28 PM
