Old 07-03-2013, 01:22 AM   #15
PSJohnDoe
I've reset my ECU twice now for parts upgrades making 3 times I've had to drive it to let the ECU learn the engine. It has done this every time, and it seems to go away after a couple/few hundred miles. I have the AT as well. Anyone else verify this adapting behavior that I've seen?
PSJohnDoe is offline   Reply With Quote
Old 07-03-2013, 02:04 AM   #16
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by dttaz View Post
I think its just because im so used to driving a stick and being able to control thd engine speed before letting out the clutch.
Oh sorry I was replying to @mikeg7827
Via my Note 2
Freeman is offline   Reply With Quote
Old 07-03-2013, 09:31 AM   #17
JDM FRS
JDM FRS's Avatar
Drives: Scion FRS(Whiteout)
Via my Note 2
Oh my bad, I didn't see that.
Sent from my HTC VLE_U using Tapatalk 2
JDM FRS is offline   Reply With Quote
Old 07-03-2013, 01:09 PM   #18
strat61caster
strat61caster's Avatar
Probably because with drive-by-wire and the goal of 30+ mpg the transmission begins to engage a little before the throttle goes wide open, by the time it figures out you've got your foot to the floor the engine is already loaded and it takes a moment to get moving.
ineedyourdiddly
JDM FRS (07-03-2013)
Old 07-07-2013, 04:50 AM   #19
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Mine definitely does it less frequently after it's had time to properly adjust, but it's never completely gone. Very conditional/sporadic after a hundred miles of driving post-reset, but still takes place occasionally. I hate that toe-in bog sensation. :\
Nightbringer is offline   Reply With Quote
Throttle Response CamryDS Northern California 27 03-31-2015 04:35 AM
BIG THROTTLE 70 KIT @ JAPANPARTS JPxM0Dz Engine, Exhaust, Transmission 10 12-19-2012 06:43 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
Throttle Controllers harajukukei Engine, Exhaust, Transmission 31 07-28-2012 01:40 AM
