#15 |
Drives: Black 2013 BRZ Limited Automatic
Exactly what I'm saying jamesm.
#16 |
there are other options for cores in the meantime
http://www.holley.com/21310ERL.asp http://store.max-redline.com/servlet/-strse-309/Detail http://www.racerpartswholesale.com/p...b_Oil_Coolers2 http://www.rallysportdirect.com/Gred...-STI-2002-2007 http://www.summitracing.com/parts/bmm-70297 this one looks tits http://www.summitracing.com/parts/der-13950 http://www.summitracing.com/parts/der-15800
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#17 |
I know. I offered to buy one elsewhere if they would refund me the price of the cooler or let them buy it. They weren't interested and I didn't see the point in spending another 150+ to fix a 600+ dollar kit.
#18 |
Drives: SWP BRZ Limited
I have one of the first Oil coolers they sold, its been in my car since I installed my Supercharger back in February, I'm happy to report no issues with it whatsoever. I did get an email from @PERRIN_Chris a week ago asking me to check my oil cooler, and as I said no leaks at all.
12 SWP BRZ-L
#19 |
Drives: 2013 WRB BRZ Limited
IMO it seems as though Perrin is taking the correct course of action. Pull all stock and send them back to be tested.
I'd rather have to wait on a replacement that's been fully tested then just keep swapping parts and crossing my fingers that it's a good cooler with no leaks. Say they did send you another cooler and it leaked also. How many times would it take before you'd being making posts on the forums bashing them because they keep sending you defective parts? Their trying to do the right thing here and you don't seem to care. You just want it NAO!!!1!ELEVEN!!1!
#20 |
Because compromise ®
Drives: Red Herring
If there was a problem with the one you purchased else where whose warranty problem does it become? Perrin's because it was a replacement part for their/Mocal's faulty part? The 2nd vendor where you got the replacement part from? I can understand why Perrin would not want to go down this route. Just from what I have read here Perrin is endeavoring to get this issue sorted out. It sucks that you are having to wait but at least you aren't like 20,000 kilometers away from Perrin like me. My Perrin oil cooler gets fitted next week. Bought locally but I would have to wait weeks if there was a problem.
#21 |
Drives: Black frs project
#22 | |
Drives: FRS Silver LS1 swapped.
#23 |
Label has been sent, sorry we didn't have any left to trade you on.
Perrin is working on the issue, it's hard when the supplier of a core component ( Mocal ) is having issues, takes time to work that out. Just unfortunate timing here is all.
#24 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I'd be all about some Robispec but the cooler is likely too wide and the lower oil cooler line fitting will definitely not allow brake cooling hoses between it and the frame rails onward to my backing plates.
If you made one the same width across as stock but still nearly as thick and with a lower oil cooler fitting that didn't impede that space between the frame rails, I'd buy it. |
#25 |
try this routing absolutly no conflicts
if you want picts email me at evo4fun"at" gmail "dot" com
Bottom photo – right side of car
#26 | ||
I'd get it if there simply weren't any of that part to be had but that isn't the case. |
#27 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
The radiators were pressure tested according to the manufacturer, but obviously they didn't do a very good job with doing it.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#28 | |
Sorry, again for all the headaches. We've been in contact with Mocal, and they have not given us an ETA on known good cores. We don't feel comfortable sending out any more cores until they are tested by Mocal to make sure 100% they are good to go. We do have a solution, but unfortunately it's going to take some time since our kit was designed around the Mocal kit, and we will have to wait till they can figure this out for us. |
| DIY- Perrin Oil Cooler/ Bumper removal notes | Splat | DIY (Do-It-Yourself) Guides | 30 | 08-27-2014 02:12 PM |
| You want it, you got it: PERRIN Oil Cooler GB | JoeBoxer | Groupbuys | 96 | 06-16-2013 04:10 PM |
| Perrin oil cooler trouble | ft86me | Engine, Exhaust, Transmission | 9 | 04-29-2013 08:56 PM |
| Perrin Oil cooler install review | LeeMaster | Engine, Exhaust, Transmission | 3 | 03-14-2013 11:41 PM |
| Perrin oil cooler group buy? | white devil | Engine, Exhaust, Transmission | 6 | 02-10-2013 04:17 AM |
